tramp question
i just purchased my first catamaran (Prindle 16) and the it came with a brand new mesh tramp that i had to install. Took the boat out for the first time this weekend (what a blast) and noticed my knees and elbows were getting sore from the tramp. Questions are:
1)it appears the tramp has a fairly coarse mesh. Do they make different materials, some being more comfortable than others?
2)Any chance this will soften over time?
thanks
Todd
Stam689
i am sure you can get one made from an after market tramp maker. i prefer mesh as it lets water drip back.. and not puddle. also i believe it makes righting easier as the wind isn't pushing the boat down with the tramp... (as much)...
Many people wear knee (and some elbow) guards when sailing for that exact reason. not a bad idea. another method is to make sure you don't drag any open body part on the tramp as you move.. takes practice but very possible...
http://www.sailingproshop.com/Products/Musto-Knee-Pads__Musto_AS0630.aspx
Yeah tramps will abrade your knees (and elbows). Generally there are lots of things on the boat that can potentially hurt. I usually wear a long sleeve rash guard on top and shorts and knee pads on the bottom and water shoes. Wet suit pants are better for keeping the boat from 'biting' you but if its hot they are not much fun.
1981 Nacra 5.2
Yes he is. But the truth is that there is no rule that says you have to use the hobie bob. Instead they make you use sails with that ugly red/yellow/turquoise pattern that is stock on the wave and getaway. Seriously could they have gotten anymore 80s with it?
D.
1981 Nacra 5.2
I don't find the tramp itself too bad, or the lacing, (I used Amsteel Dyneema, strong soft & slippery)it is the stitching around the edges of the tramp that are meat grinders. I just try not to slide around that area, but have a few abrasions to show for it.
lawrencer2003 wrote:
If you wear knee pads, I think most class rules says that you have to have a hobie bob also.
I you are not abraded, sunburned, and bleeding at the end of the day, you've not been sailing hard enough! Thats what beach coctails are for!
Amen brother
I got up to the cottage today after blowing the best part of a week with the family in San Francisco,(they set a record for heat, 33C as we biked from pier 39 to Sausalito, Muir Woods & on to Tiburon, but their water would make our Eskimos hypothermic)& moving kids back to university.
The wind was 15, gusting to nearly 30, I went out with just the main, as some jib stuff is at the sail loft. You just can't make the speed minus the jib, so I started screwing around to see how fast I could tack & gybe. By the end of the hour I had two black marks on my wrist when I wasn't quick enough while gybing in 20+.
The only reason my knees were still intact was I wussed out & put on a wetsuit as it was overcast & cool. My wife was having none of it..."go enjoy the beating you will take, I'll have the wine opened & the jacuzzi full when you return."
It just isn't as much fun unless you are on the edge of swimming!
edited by: Edchris177, Sep 09, 2010 - 10:17 PM
The first day there it got to 28 ish, the next day was a high of 33C. That beat the old record of 32. The next day it was down to 19, & you couldn't see one iota of the bridge, the fog was rolling in below the trees.
I used to layover in Frisco quite a bit when i flew domestic,(we consider the States as part of the domestic network). I remember temps never getting above 20-25 ish & quite a bit of fog off the ocean. San Diego, only a hop as the crow flies was a totally different climate.
I was told the water under the GG bridge is around 45F, & the Bay stays a constant 54F, that is bloody cold, even for someone who spent 10 years in the high Arctic.
There were a few people with wetsuits swimming laps in the park just in front of Gharedelli (sp?)chocolate, next to the Presidio. Outside the breakwall the waves were 3' and solid whitecaps. There were a few lead sleds heeled over, & 2 kiteboarders ripping it up.
Ahhh forgot you guys work in that antiquated farenheit scale. We get the aviation reports in celcius, but I think all your public weather is still F
33C= 92F
edited by: Edchris177, Sep 10, 2010 - 02:05 PM
One tramp notorious for carpet burn is a SuperCat tramp, which is a bigger mesh then most. I have a mesh tramp on my H18 now and don't have much problem, have had vinyl tramps in the past also. But a weekend on a Supercat mesh tramp will have you bleeding unless you are well protected. Thankfully the SC20 boom is high enough you can get under it without dragging across the tramp, unlike a H16 for example. The Supercat tramp will chew your wetsuit up also if you aren't careful.
Hobie 18M in Chicago
C'mon Andrew, fess up. What was so heinous that you had to change your name?
Did you undergo a sex change operation, come out of the closet? Ex trying to hunt you down for 1/2 your Cat?
I'm open to dialog with others no matter what their leanings, hell I wish 80% of men were g.a.y, just think the women would HAVE to fight over the rest of us!
Now, the thought of you trying to sail your cat as a monohull is funny, in a sick sort of way.:-)
edited by: Edchris177, Sep 11, 2010 - 11:18 AM
This reminded me that my h16 had a hound on the boom. i think it was for a boom vang. That thing took out a few crew members and even the skipper (me) one time...
- 1 Online
