Prindle 15 pros and...
Prindle 15 pros and cons
7 Users
Peter knapp
(@pknapp66)
I am looking at a Prindle 15 for sale locally and was
wondering if anyone here has any experience with one.
I currently sail an H18 and would like a play boat for a
small local lake. Asking $500 but needs some work.
H18m
p16
Venture15
Posted : June 14, 2009 4:32 pm
FranB
(@FranB)
Hi ,
Take a look on Ronde om Texel ! The name Dirk Pool and his P-15 !!
Posted : June 14, 2009 8:08 pm
Dan
 Dan
(@DanBerger)
$500 for any boat is a good price if it doesn't need too much work. If the decks are soft, don't get it. If it is minor fiberglass or gell, and you can do the work, then go ahead.
Pros: Prindles are good, solid boats. They are very tough and durable. The beams are attached directly to the hulls, so they don't flex and feel very rigid. You could probably right a Prindle 15 easier than a Prindle 16 or Hobie 16, but that is strictly going on size.
Cons: There aren't as many Prindles out there as are Hobies--and the 15 is very rare. Finding parts will be your big issue. Prindle 15 specific parts like masts and hulls will be about impossible to find used. You will probably have to modify a 16 mast if you break yours. The steering is good on the Prindles, but the castings break and are hard to find used when you need one. If you get the Prindle, immediately start looking for castings. Used sails and tramps will be hard to find, but you can get those new. There is a jib on eBay right now and he is offerring a main as well.
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
Posted : June 15, 2009 7:13 am
FranB
(@FranB)
Hi,
Take a look by Ronde om Texel 2009 , and find the name , Dirk pool and his P-15 !
Posted : June 15, 2009 7:17 am
Martin
(@UFgator)
For that price it must need work. Parts are the only problem with Prindles these days. If you can find out what parts are needed to get her up to speed check their availability and if you can get them go for it.
Martin
Posted : June 17, 2009 7:47 am
Kenny Gatesman
(@kgatesman)
Contact Murrays.com to see if they carry or can source parts for the Prindle 15. They have had everything I have needed for my Prindle 18 and things they didn't have in stock they were able to special order.
Kenny Gatesman
Chicago sailing at Wilmette
Posted : June 17, 2009 9:23 am
Fraser
(@northerncat)
For parts you can sometimes get away with using Hobie parts.
Fraser
Posted : June 19, 2009 3:56 am
Elias
(@HULLFLYER)
The good things about parts:
All Prindle rudder castings and gudgeons will fit all Prindles
Rudder blade 15/16/18/Escape are the same
Tiller crossbar 15/16/18/Escape are the same
Rear crossbar 15/16/18/Escape are the same
Front crossbar 15/16/18 are the same
many other small parts associated with the above are the same
Posted : June 19, 2009 6:58 am
Peter knapp
(@pknapp66)
Someone beat me to the 15. Today I ended up buying
a Prindle 16 on a trailer for $375. It is in decent
shape but needs a tramp and when I got it home I realized that the jib blocks were missing.
H18m
p16
Venture15
Posted : June 20, 2009 11:07 am
Elias
(@HULLFLYER)
I have a set of Harken ratchet jib blocks if you are looking for a set. 5*6*1*3*0*5*1*3*4*9*
pknapp66 wrote: Someone beat me to the 15. Today I ended up buying
Posted : June 21, 2009 1:19 am
