How much is this boat worth?
Hey all,
I'm looking for a price check on this catamaran which was given to me by a relative. My brother and I sailed it last summer and it was a blast, but he's going away to school. Raising the mast and sail is too difficult to do on my own. I would like to sell it and buy a smaller cat like a hobie or something similar. Can anyone give me a sale value?
Here's some more details and a few pictures:
It has a good trailer
trampoline is in good condition
no holes in the sail (some broken battens though)
almost all of the hardware save a few pins or bolts
hulls are completely seaworthy. one hole was glassed over and does not leak.
One set of trapeze wires and two harnesses
It is a 5.5 late 80s/early 90s I believe.
Please let me know what you think!
Kevin
http://imgur.com/71Xj7,IlGQh#1
$2000?
the 5.5 uni was the replacement to the nacra 5.2
nacra said at the time that it was slightly lighter, though i struggle to believe that
going to be similar in weight to a hobie 16
so if you want a cat that's lighter and easier to rig you might need to go right down to the hobie 14 or wave
Edited by erice on Jul 09, 2012 - 04:16 PM.
1982 nacra 5.2
2009 weta
Hi,
Raising the mast will be about the same effort on any cat in that size range. Check out gin pole setups in the Hobie catalog, or just get a helper. When stepping a mast, I attach a line to the main halyard, while keeping the other end clipped to the base of the mast. The second guy stands about 20' from the cat and assists in raising by pulling on the rope. He's also the safety guy who holds the mast up while I get the forestay attached. It's pretty e-z with two people.
Thanks for the great info everyone! I thought it was worth about 1000$ so I'm pleasantly surprised that it's worth more.
Damon, the hull ID is NACF0259C888. Yes it is a 5.5. And the sail is in decent shape, it has some broken battens though.
Quarath, I do want something that would be easy for a beginner to handle solo.
Although from what I'm reading I may be simply misinformed in thinking that it will be easier on a different type of cat.
Thanks for the info on raising the masts.
The sail is incredibly difficult to raise, which is the second major problem next to actually getting the mast up. Using the halyard is nearly impossible because the part of the sail that goes into the mast (not sure of that terminology) gets stuck while feeding it in. It takes a ridiculous amount of effort to get it only a few inches because of all the friction. We usually have to resort to flipping the boat over and having one person manually tug the sail while the other feeds it into the mast.
I know I'm getting a little off topic here, and I can create a new post if need be. Once I figure out raising the sail I'll have everything I need to either sail this baby or get it sold.
very common, here are a few solutions:
clean the track.
Many methods, I use a little piece of a t-shirt, wrapped around a 3" dowel or pencil. use Acetone (or similar solvent) and run it up and down the entire mast track (a few times)... removing it and adjusting the t-shirt cloth to a clean spot, and re-apply solvent. repeat till clean
Lubricate the track:
same method but with silicone lube. some people spray McLube (dry silicone) into the track, but i think most of the product lands in the wrong spot and doesn't help that much and is about $20/bottle.
Make sure there are no pinches in the track
Often tracks get bent from trailers (or the occasionally falling down on a beam or other boat). so while cleaning and lubing the track, inspect for pinched areas. they can be gently pounded out with a wooden shim (think doorstop shape)
Check/replace your sails boltrope
this is the part of the sail that sits in the track. they can swell from moisture overtime and can be replaced with a new/smaller diameter for around $100-200 at a sail shop. i suggest you DO NOT have anyone other than a sail maker do this repair.
Value of your cat:
i would say $1000 - $3000 range depending on is condition, time of year, and parts.
If you clean it up, make sure it is 100% ready to sail (all pins, all battens, good lines, ,etc) at the beginning of the season, it could be worth $3k to someone. if it needs any work, or parts it's probably worth much less.. end of season, incomplete cat... i would pay around 1200,
PS i would get a gin pole (or crew), and keep that boat and not even think about an "easier boat" ....
RSabast wrote: Green,
Take some very very fine sandpaper or steel wool and polish the aluminum in your track. Years of oxidation means a rough surface. When it's all shiny, hit it with some silicon lube.
I am no expert in metals, but wouldn't that remove the paint or anodizing and open up your mast up to corrosion?
it shouldn't
the nacra masts of that period seem to be simple bare alloy, no anodizing or painting
if it's rough and pocked inside the track from years of salt water corrosion it could be very rough
some sandpaper wrapped around a small dowel and shunted up and down inside the sail track a few times with something thin should help smooth it all out and the newly bare alloy will simply re-oxidize it's normal tough layer
1982 nacra 5.2
2009 weta
By very fine he means 1000-1500 GRIT, automotive paper
Correct if the mast was originally anodized.
Many people think aluminum is quite resistant to corrosion. In fact it corrodes quicker, much quicker than cast iron. The good thing is that it morphs into aluminum oxide, which is almost impervious to oxygen. This prevents any further corrosion, hence you can scratch the coating of an aluminum object and not see corrosion creep out of the damaged area...actually Eric said the same thing in less words!
Your Hull VIN shows it is a 1988 boat.
Andrew (MN3) pointed out a very common cause, the bolt rope. The rope is secured to the sail by coarse stitching. If the rope shrinks, or the sail stretches you get wrinkles in the fabric along the bolt rope. These wrinkles will cause the sail to bind in the track. Fix that & your problem is solved. Also make sure when you raise the sail, don't just haul on the line, the sail will bind every time a batten hits the feed track, you often have to grab the sail & line up where the batten cap area feeds into the mast.
Finally... are you raising the sail while pointed directly into the wind? If the sail is being blown against the trap wires or shrouds it can be bloody hard to raise. If it is off a bit, you can tug on the diamond wires to turn the mast a bit.
