Um, how about some gel on those rudders??
So, I went to an auction this weekend and there was a Trac 14, Hobie 16, Aqua cat 12, and a Laser II. I got the Hobie and the Laser, but couldn't bring myself to even bid on the Aqua cat (though it had a nice trailer) and I was actually out bd on the Trac. The guy who got it was a big, fat country boy with mismatched camo. I think he just wanted the trailer because he had no idea what was on it.
I noticed something wrong with the Trac, the rudders were a brownish yellow color--What I was looking at were the foam core plugs of the rudders because all the gel coat had rubbed off!!!
Dan Berger
Nofolk, VA - Hobie Fleet 32
Supercat 15
A Cat USA139
That's a Sahara Cat rudder- very popular in the dunes.
The Saharas get lighter as you sail them- what with all that heavy gelcoat and resin wearing off.
Gybing as you crest a dune is quite a rush!
The downside is stuffing a hull and doing a face plant in the very materal from which they make 40 grit sandpaper.
Though if you choose your sand carefully the resultant dermabrasion could be a healthy benefit in a heavy acne or ugly tattoo situation.
It was like a country auction where they took consignments from stores that went under, storage unit buyers, thrift shop owners. They also had estate stuff. The boats came a long way from a marina on a lake. I think they were abandoned.
They auctioned off chickens, tractors and a collection of old plows (lawn ornaments). I never thought I would end up a a place like that.
Dan Berger
Supercat 15
A Cat USA139
It is my understanding that sand is not used in sandpaper
Materials used for the abrading particles are:
flint: no longer commonly used
garnet: commonly used in woodworking
emery: commonly used to abrade or polish metal
aluminium oxide: The most common in widest variety of grits, lowest unit cost; can be used on metal (i.e. body shops) or wood
silicon carbide: available in very coarse grits all the way through to microgrits, common in wet applications
alumina-zirconia: (an aluminium oxide–zirconium oxide alloy), used for machine grinding applications
Chromium(III) oxide: used in extremely fine micron grit (micrometre level) papers
ceramic aluminum oxide: used in high pressure applications, used in both coated abrasives, as well as in bonded abrasives
Klozhald wrote: The downside is stuffing a hull and doing a face plant in the very materal from which they make 40 grit sandpaper.
mn3 wrote: It is my understanding that sand is not used in sandpaper.
It was a joke, but thanks for the information. :/
