Spinnaker, is it really worth it?
Hi, I am new to this forum so i'll start by explaining my story... Also, I am french so don't expect good english in my posts 🙄 :
I started Cat Sailing this year with a 1982 Mystere S (17 foot catamaran) wich was a blast to sail, unfortunatly the mast and the main sail broke in a small accident that I had. Since I enjoyed Cat sailing so much, I immediatly bought a Mystere 6.0 year 2000... I got better at sailing and I am now looking for a new challenge and was thinking about installing a spinnaker system. So my first question is : is it worth it? Second, does anyone here have the experience of installing it themself? If so, any tips or pointers will be appreciated... I am especially worried about drilling holes in my mast. I am not quite sure wich tool is the best and what to do to keep it water tight.
Let me know!
-Phil
lucky for you, cat sailing is bigger in europe than in the US, so you should have lots of help.
go sail on a cat with a spin, you drive, and see what you think.
I have a Hobie 18, sailed it for 3 years, and decided to put a spin on... YES it's worth it!
Gather up some used stuff, meet some folks who are upgrading theirs... you buy some things new, and save money with their used items.... Look at other boats for installation methods.
You can drill into the mast, no problem. Use "rivet caps" then the rivet, and some silicone, you'll be fine. Biggest thing is go sail and try it out... and study how other boats have their spinnakers setup.
H14T, H18SX... Ocean Springs, MS www.osyc.com
Hahaha. Rob, he's in Ottawa not Europe. Anyway, same idea, lots of cats in that part of Canada. You should be able to hook up with someone to take you out. If you sail on a relatively big lake, it will definitely be worth it. I sail on small lakes about 10 mi by 10 mi and it isn't worth the extra trouble for me.
Talk to Dave at Nacra Canada www.nacra.ca. He sells quite a few spin kits as add ons for older Nacras, they will work fine on a Mystere. You can also call up Mystere in Quebec www.mysterecomposites.com, they have a school and should be able to give you some good advice, in French. My french is so bad I'm not even going to try, my dad is so disappointed in me.
Edited by Wolfman on Sep 12, 2012 - 09:51 PM.
1981 Nacra 5.2
i sail a mystere 5.5 and sail with a small fleet of 8 or 9 mysteres (5.5's, 6.0, 6.0XL's)
we ALL have spins. IT IS VERY MUCH WORTH the expense, trouble, frustration, etc
they are expensive (about $700-800 worth of hardware + about $1400 for a new spin) BUT SOOOO WORTH IT.
When it's light air and people are slowly drifting downwind... you can heat up the spinnaker and blow past them. When its medium air... you can fly your cat around like a rock star. When it's heavy air you can get on the wire, fly a hull and really feel exhilaration as you sail on the edge
when it goes bad with the spin.... it goes really bad BUT still... SOOO WORTH IT!
Learning and using a spin is an entirely new way to sail and brings a huge new level of excitement (and fear) into sailing...
I don't think I'm overstating saying that being trapped out solo with the kite up is exhilarating.
I'm considering a kite for my next boat. I can do 30 mile runs, one way. Did a 50 mile trip down the lake around an Island & back on Wed. We often get days of 5-10mph wind, & being able to find excitement downwind is an interesting option.
I solo about 85% of the time, on a 2 man boat. You mentioned soling with the kite. How much more complicated is that?
That's what I was wondering. I have never been on a boat flying a kite, & don't know how viable it is to single hand with one.
Hopefully this winter I will get the chance to hang around some beaches & see firsthand how they are rigged & handled.
I don't know too much about the mechanics of going solo with a spin boat but I know tons of people do it. I mostly crew on 2-man spin boats. I know that the main is the back stay and you definitely don't want to blow it to depower. In a big gust that would likely bring down your mast. You adjust the main with the traveler so that the sheet stays tight. You depower by pointing lower. The best rides are when you can get the hull just out of the water and point higher to power up and point lower to depower. One hull being pulled by a huge kite is an incredible experience with 2 people on board. I bet it is pretty close to nirvana single-handed.
So it IS possible to go out solo with a spin?! Sounds Great, I will definetly be trying this haha
Yes, it is no big deal at all.. i do it all the time, as Rob said above " you dont need the mainsheet in your hand with a spin out", so it's no big deal.
the only time crew is really beneficial is during hoisting or snuffing, it's always easier to have someone grab the helm while you snuff (or bag) the spinnaker.. but still very doable solo
I would have a hard time moving to a non-spin boat full time again.
Make sure you do what you can to make hoisting and dousing as easy as possible for speed and less complaining from crew.
I have had 3 trapped out on my boat on a spin run a couple times with still way too much power. Tons of fun.
Yea, the only thing I am worried about right now is installing it and the cost. Mystere Composite near where I live could install a brand new system on my cat for 3k :-O ... Way too expensive for me 🙁 . So I just have to wait out and find a used spin and then build my own spinnaker system. 😀
Yea, the only thing I am worried about right now is installing it and the cost. Mystere Composite near where I live could install a brand new system on my cat for 3k icon_eek ... Way too expensive for me
new alum 13'2" pole - $100 (less for used)
used Tornado spin (fair - to good condition) - $300-700
55mm rachet blocks (2) - $110
55mm non-rachet blocks (2) - $80
tang/block - $40 (guess)
tack block - ($25)
tackline - $10
halyard - $50
spin sheet -$50
$465 plus the spin (whatever you find)
can be done for around $1000
tack block - ($25)
tackline - $10
halyard - $50
spin sheet -$50
$465 plus the spin (whatever you find)can be done for around $1000
Yea that is what I calculated too, around 1000$. You just haven't included the snuffer. But maybe I could be able to make one by myself. By the way, is it really better to install a snuffer? I don't think I could be able to get it out solo with the spin in a bag ? Is the difference worth it?
the weta tri can be soloed with 3 sails up
first you cleat the main and jib, then unfurl the gennaker
when sailing you keep 1 hand on the tiller and the other on the spin sheet
if you get over-powered you steer down, release some sheet, or both
a few things you need to keep in mind
1. there is no window in the spin so it has a HUGE blind spot which can be dangerous when it's crowded...
2. as steering down is the main bailout option be careful not to sail too close to shorelines and other boats when it's gusty
3. you will eventually get hit by a gust too big to be able to steer out of and releasing only some sheet will simply deepen the pocket in the sail and power it up even more...lifting the rudder out of the water, burying the bow and over you go.....so know how to right your boat solo
4. putting the spin away is often a 2 handed job so it helps to steer down early and have some kind of stiff rudder so the boat doesn't round up when your hand is off the tiller
ps a bag launched spin is harder again and probably only safe to use when soloing in light winds
1982 nacra 5.2
2009 weta
you can start without a snuffer - much easier with crew as it takes much longer to stuff a huge sail into a bag
Out (and in) of a bag is much easier with a snuffer system
the snuffer is defiantly worth it (esp f you sail solo)
PS i wouldn't make my own unless i was a metal fabricator ... homemade snuffers dont usually work very well and risk tearing the spin
you are correct, as you sheet the spin out .. it powers up..
but, you can usually dump the spin sheet to save yourself, but your spin will flog like crazy (who cares)
I have never (personally) capsized with a spin out, and i am currently on my 3rd spin
i have been crew (in a race) where the skipper sailed to high after a jybe and we capsized with a spin out
and i have seen my pal dump right in front of me because he tried to steer up to depower (deeper/more dead-down-wind would have been correct) and capsized, but both times, it could have been avoided by dumping the spin sheet.
Edited by MN3 on Sep 19, 2012 - 09:11 AM.
