SpeedPuck- Pros and Cons?
I haven't got one, just use a handheld Garmin eTrex on a lanyard and stuck in my PFD pocket. Of course I drift off-course every time I pull it out to take a look. 😀
Having a "speedometer" on board like the SpeedPuck would be awesome, too bad it's so expensive. Don't really understand why it costs more than seemingly more sophisticated items like handheld GPS and GPS sports watches.
Having a big display like that would be great, might need two of them, mount one on each side of the boom!
Speedpuck is a valuable tool when racing, especially WL courses. It shows subtle shifts keeping you in tune when your getting knocked enough to tack, or when you are getting lifted, and also micro changes in speed.
Best place to mount on a spin boat is just in front of the jib. Easily visible anywhere on the boat which is one of the reasons it is helpful when racing.
As for recreational sailing probably won't do much for you other than give you a heads up display of speed.
FYI, you can download the data at the end of the day.
beachsailor wrote: Just good fun to see how fast you are going and max speed for the day. You need to mount where it is visable on both tacks. This is a fairly large display. The lift header display is nice because you can see when you are pinching or footing.
Have you ever used it on the neck lanyard?
If you have a android phone download bc racer off the market. Will give you lift indicators...can set wind direction...mark locations....has start timer.....speed....and it is only a few bucks. I mounted a waterproof case for my phone designed for a motorcycle handlebar to the tramp just behind the mast base...works great
mummp wrote: Best place to mount on a spin boat is just in front of the jib. Easily visible anywhere on the boat which is one of the reasons it is helpful when racing.
Foreward of the jib- as in on the bridle, or back near the mast?
How did you mount it?
Hey Bob,
As I mentioned, I was referencing the set up on a spin boat, which would be "in front of the jib", on the spin pole. I have seen my share of other custom set ups which can get complicated and expensive.
The manufacturer provides mounts for the puck, and the cost of the puck/mount can get rather expensive. Just my opinion, but if your not seriously competitive on the racing scene, your money would be better served with a handheld GPS. The handheld GPS would provide so much more information and customization for your daily needs (i.e. The Tri-Point Race)
I too use a Foretrex 201, and like its ease of use, and the convenience of having it there on my wrist. I prefer the 201, which is now out of production, because of its sealed case(rechargeable battery). I still find them new, refurbished, or lightly used, on Ebay, usually for under $100. The wrist strap is very tenatively attached, so I glue it to the case with shoe goo or aquaseal. This trick won't work with the models with replaceable batteries, as the back of the unit gets removed to change them, and that's what I glue the strap to. If you can keep it attached to you, it's quite durable for catsailing, surviving regular dousings.
I can see the speedpuck being more useful to racers, but for recreational sailors, the etrex and foretrex models work well.
a couple of years ago, i bought a garmin forerunner 205 at walmart for $125. here is some info from walmart for the 305 model.
there are newer versions but i've been really happy with this wristwatch. what you want is something that's hands free, not in your pocket or on a lanyard where you have to let go of a sheet or tiller to get it out, just twist your wrist over and look at the watch.
this watch can show your present speed, your maximum speed (which is important because you may not want to look down when you're screaming along!) the time of day, all on the same screen. when you're done, plug it into your computer and download the data to google earth and it shows a red line tracing your path right over the aerial photo of your lake. it also graphs your speed and time on a chart.
it does all the things a runner or biker would need as well and it's waterproof to the depth we go when capsized (or so i've heard, cause i never capsize.......)
if you drop something in the water, you can hit a button on the watch to mark your location and it will direct you back to the same spot using arrows for direction and distance. use it for hiking to make sure you can return to the place you started. i can't remember everything it does but it has so much more power than the speedpuck for the money.
read all it can do in the manual, which is probably online somewhere.
have fun!
Edited by arch on Feb 01, 2012 - 09:14 PM.
cool mounting idea
shipchips1 wrote: cool mounting idea
Great way to mount it!
Thanks Jim!
jward1081 wrote: I mounted a waterproof case for my phone designed for a motorcycle handlebar to the tramp just behind the mast base...works great
Can the skipper see this, or does the crew need to shout it out?
In what mode do you use it most mounted to the tramp?
Edited by klozhald on Feb 08, 2012 - 09:28 AM.
DamonLinkous wrote: Having a big display like that would be great, might need two of them, mount one on each side of the boom!
ShipClips1 mounting post is impressive. If I get one I will try this.
The advantage I seek with a tools like the SpeedPuck is being able to tell immediately if the sheet trim or rudder turn I just made was for better or worse. This seems a nearly invaluable training tool, not to mention racing. A tenth of a knot is big news, and yet hard to feel. With it mounted where you can see it, the Sp seems ideal, but really expensive. I have looked at phone solutions and while they are good, the readout is small and must be carried on my person.
As an update to this thread, I have not acquired a SpeedPuck due to the cost. I received much better bang for my buck with new lines, tramp harness, safety gear and a trampoline. As a training tool, I think a SpeedPuck mounted on a swivel under the boom would be of great help in learning the finer points of sail trim and helmsmanship, as well as clearly showing heading without having to find your hand-held. It will have to wail until greater priorities are served.
I found a sturdy workable waterproof case for my phone and have downloaded the MotionX-GPS application. The app is a bit complex at first, but has all the features I need from a GPS, including NOAA marine coastal maps. At US$4.00, it was a value. The case was $28, makes the phone float, and I can use the touch screen through it without problem. Finding a spare hand to lift the device while sailing is a challenge, but would be the same with any hand-held GPS.
We have SpeedPuck and mount it on the spin pole right under the luff of the jib. It is very visible on both tacks. While we do a little racing, I found it most helpful on light air days when you want to maximize what little wind there is. We use the speed setting to tell us if we are pointing too high when going up wind. Its amaizing to see how much speed you lose when doing a tack.
Thanks!
Eric Weller
Keep the pointy side up!
bacho wrote: I have found my iPhone very difficult to read in the sun and battery life to be a major problem to be used on the boat.
I had the same battery problem initially. Turning off wireless, bluetooth and 3G in the phone made a big difference in battery life. The latest software update has a more contrasty readout interface, but I have yet to try it in the summer AZ sun.
Interesting!! I wonder if they are using "offshore" resources to build and test their units.
When I first received my SpeedPuck, it could not get a satellite fix and I had to send it back for exchange. They obviously don't turn them on because it was immediately apparent on mine that it wasn't working. It sounds the same for your unit.
Have them send it back to you overnight and make them throw in a hoodie! I wish I asked for a hoodie but they did ship it overnight at their expense.
Thanks!
Eric Weller
TahoePrindle18 wrote: We had a speed puck on my Stiletto 27 for first time this weekend.
It got cooked in the sun and now only reads "1.45" and is stuck on that display.
Removing batteries has not fixed it.
So it was in direct sunlight at like 95 degrees for a day and that killed it?
It will melt off my boom in Arizona. That isn't going to work.
Disappointing.
klozhald wrote: So it was in direct sunlight at like 95 degrees for a day and that killed it?
Disappointing.
Bob, great product, well designed, tough as nails, and backed by great customer support. It ain't gonna melt. As with any electronics, you get a problem some times. Al, is it still in the warranty period? Customer support should take care of it.
Klozhald wrote: [quote=bacho]I have found my iPhone very difficult to read in the sun and battery life to be a major problem to be used on the boat.
I tested the app on the lake for three hours this weekend with dissapointing results. The app (MotionX-GPS) works well but with the iPhone in a waterproof bag around my neck the screen was not bright enough to see effectively. I have used the software quite a bit in rehearsal prior to this, but I did not memoriuze the location of buttons or the sequence of screens, so I barely got a tracing of our 3 hour path and a few on the go readings of our speed and direction. The bubbles trapped by the AquaPac film over the screen could be eliminated and this will help, but I can't say I have resolved that yet. The battery usage was good with everything else turned off, though. I had 68% battery left after three hours.
If you're mounting an iPhone or iPod on the boom or on deck, do you think some form of hood would give you the contrast you need to see the screen? I use one on the screen on my photography rig, and it works well. But it's got a really restricted angle of view.
It's just some black ABS plastic bent into a box shape and attached with Velcro. Leaving the bottom open like that gives access for fingers (important on an iPhone, but not so much on a monitor like this), but if you can set up the iPhone first and then slap the hood on, the hood could be a complete wrap-around.
I haven't tried this yet, but I was hoping to. I'm just bummed that most of the iPhone speed apps won't do decimal knots. I'd like to know if I'm doing 11.2 knots versus 11.6!
benedict wrote: I haven't tried this yet, but I was hoping to. I'm just bummed that most of the iPhone speed apps won't do decimal knots. I'd like to know if I'm doing 11.2 knots versus 11.6!
MotionX-GPS does show decimals in miles and knots. They may have a free version, but I bought the full app with NOAA map for US$4.00.
Hey cool! $4 is cheap compared to everything else that goes into a boat. I may go ahead and install it, and try this with a hood.
Barring any unfortunate accidents, I should have my boat out on the water this weekend (FINALLY!!) so I can start to play with all this stuff!
