ο‡ͺ
ο…•
οˆ‘
Sail numbers and serial numbers
6 Users
(@makinmajik)
Is there a relation between sail numbers and hull serial numbers? I am curious about Prindle in particular. I saw a topic that talked about Hobie but it never really stated if the two were related. I would think that the sail number would be the last four of the hull number, but that might be just my car background showing.
Posted : August 26, 2011 1:36 am
Scott Finley
(@smfinley)
Typically the last 2 digits of the hull number is the year it was made. Beyond that I am not sure how the hull numbers are determined. The sail numbers from the factory are typically in sequential order of when the sail for that model of boat was produced. So I do not believe there is a way to connect the two, but my experience with with Hobie's and Supercats, not Prindles.
Also note a lot of older boats the sails have been swapped on, for example I have 3 sets of H18 sails, and honestly not sure which set was the original if any of them are.
Hobie 18M in Chicago
Posted : August 26, 2011 5:17 am
Beest
(@Beest)
It doesn't really answer the question about sails but I found this in one of the archive issues of "On The Wire"
Decyphering Hull Serial Numbers
By Matt Miller
The Current numbers can be found on the transoms of each hull. They moved to the transoms after 1973. The oldest boats ('73 and older) will find a four digit number stamped in the pylon posts. This is located on the outboard of each forward pylon post. For newer boats, during a period of time, they were located parallel to the rudder pins. They are now on the upper and outboard corner of each transom just below the hull lip.
The format is as follows: CCMX0000X000
CCM = Coast Cat Manufacture (Corporate Name)
X = Model letter (typical... 18s are C, 16s vary, Wave X, H20 P etc)
0000 = serial number
X = Letter / Month of Mfg. (A is January, B is February etc. I is not used I don't think)
000 = year of mfg and year model (797 is '97 mfg. 97 model / 697 would be a boat built in year '96 but is a 97 model. Model year starts in July
Posted : August 26, 2011 7:31 am
(@makinmajik)
Thanks for the info. I was hoping there was some way to link the two as it might answer a question I had about my boat. The picture on my avatar is a Prindle fleet photo that was taken around a year after my boat was sold on a beach about twenty minutes north of the dealer that sold it. The third boat from the left is a ringer for my boat, white hulls with blue decks. The sails are slightly different, but the sail # 4660 is visible in the photo. I was hoping to connect that sail # with my hull #. Not that it matters, but it would be neat to know that really is my boat with all it's little Prindle relatives.
Posted : August 26, 2011 8:43 am
(@thomasjbrothersjr)
Nice to see that my Hobie is a 94. Nobody knew nuthin'.
I believe my sails are numbered in the 180,000 range. I wonder what are the 16's coming through with now?
Posted : August 26, 2011 9:18 am
kevin horecky
(@Kevin219)
My 1981 H18 has a sail number of 6601 and a hull id number of 5920. Though I'm sure they are the original sails. Like my chicago neighbor said without saying, they made more sails than hulls.
81' Hobie 18
Lake Michigan South Shore Line
Posted : August 26, 2011 12:28 pm
(@solsailer18)
Dosn't seem to be a real correlation, in most cases the boat manufacturer has the sails made by some one else and I doubt that much attention was paid to ensure that the sail number cooresponded to the hull #. My SolCat is hull# 734 or something close to that, and original sail # 999. As posted above, more sails than boats... but it would be cool to know that it is your boat pictured. πŸ˜€
Posted : August 27, 2011 1:30 pm
