R21 New video May 9th 2013
Looks fun, Captain, you had the lake all to yourself. 4:20 try and resist the urge to dump the sheet the moment your hull starts flying. If the Reynolds is anything like my H-18, you should be able to steer your way out of trouble in moderate winds like that. In that instance, if you fell off the wind just a little a bit instead of dumping the sheet and then accidentally turning to port, your hull likely would have come right down. If not, then you dump the sheet (which you should keep uncleated). Does your trampoline have footstraps? You need something to keep you from sliding down. Happy sailing.
Edited by BrianCT on May 12, 2013 - 10:57 AM.
Posted : May 12, 2013 3:17 am
Forum Information
Our newest member: wpmudev
Latest Post: When will the new site go live?
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
