Poliglow alternative for glossy finish
I ran across something interesting tonight. Evidently, RV owners have been using this stuff on their gelcoat for years to get a spectacular shine. Poliglow has been the tried and true product for achieving a perfect gloss finish on gelcoat, but this stuff has shown to be just as good for less than $10 / gallon.
It's called Red Max Pro #3.
If you read through the whole discussion, no one has anything bad to say about it and it hasn't lost any shine or yellowed for anyone in a few years.
I'm thinking about giving it a try on an old Hobie 14 that I will be picking up this weekend for cheap.
As far as speed, I'm sure this isn't the fastest but it looks damn good and that counts for half the speed anyway right? 😀
kgatesman wrote: Bar Keepers Friend is good for getting blood stains out of your sails too. Not sure what Bar Keepers use it for.
I won't ask how you know to keep all of our innocence...
I wasn't able to try anything this weekend with the Red Max Pro. I'm away at school so my boat is at home. I might try doing it over spring break if I have time (I'll be focusing my time on my 16 though). I'll keep you guys updated if I find anything new.
Edited by zaxtvnz on Feb 12, 2012 - 09:36 PM.
Just a heads up: it looks like Lowes is phasing out their Red Max Pro floor product line. I went online and most of the Lowes near me are out. I talked to the guy at my local Lowes and he said they didn't have any more on order. There are a few in some random places near me so I may drive over and get a gallon or two for safe keeping.
Next week is my spring break so I am going to give this stuff a try. I'll post on here after I'm done hopefully with some before/after pictures.
They look great, Quarath! I, too, did the hulls on my H18 and was *very* impressed with the results. I couldn't find the Red Max so I used the "Zep Wet Look Floor Finish" alternative I mentioned above. I don't have any pictures to share, but my hulls turned out like yours'. Well, with one exception - I didn't bother with my blue decks because they're terribly faded and I couldn't manage to get a uniform color. How did you apply the Red Max? I used the "Poliglow" method and wrapped a chamois cloth around a block of wood. I then squirted the Zep onto the chamois using an empty Dawn dish soap bottle. Sure beats waxing, eh? Thanks again, Zach! That Barkeeper's Friend is gold as well.
Edited by BrianCT on May 22, 2012 - 03:34 AM.
I did the Red Max thing on my H17. It was not too faded so the prep was quick.. It is YELLLLOW.. Only did 2 coats cuz if did not work I wanted to have less to take off. Looks great !! Sailed 2 weekends.. Got lots of .. "Nice Boat" from friends.. I used those inexpensive flat pads from the paint dept. Asorbant but have small rug like hairs.. Green with a white foam back.. Worked geat. BTW Red Max is imported by Zep. Perhaps the same product. Got 3 gals cus it is not on reorder. Cheers Hal
Yes used small padded applicator used for waxes and just dipped it and wiped it on very lightly in one direction being careful not to leave bubbles. the 4 coats went relatively quickly. I have not done any work on my decks yet only the hulls.
My color is not great after the bottom job I applied white gel coat. I really didn't even try to mix it to color match though after I found some info where someone used a tiny bit of sienna to make white gel coat match but by then i was done. Most looks ok. I had a hard time keeping it think everywhere I wanted.
I started with spraying it with Preval. It I thinned as much as I dared with acetone and it was ok but not great. It was good for transoms where I just masked off hardware. It was too much and way to slow for the bottom job I ended up rolling it on. Don't do it when you running out of light like I did because then you just have to sand and add more. I still have some spots I am not thrilled with on the gel coat but the glass work for minor repairs and bottoms went great I am thrilled to know the hulls are sound for may years to come.
My beat up P16s will probably just get glass and paint rather than gel coat. It's too hard to match the old faded colors and 2 of them had their share of repairs.
Dustin
Magna, UT
Prindle 18
Here's a picture of mine one month later (click to enlarge). I have not cleaned or buffed the boat since applying the final (3rd) coat. If you look closely, you can almost make out my neighbor's Hobie Wave in the reflection. I'm happy with the results. Prior to Barkeepers and Zep Floor Finish treatment, my hulls were chalky white and porous - I was getting toilet bowl rings when I spent a lot of time on the water.
Edited by BrianCT on Jun 01, 2012 - 10:54 AM.
Damon, I did my hulls a year ago this past April and they still look great. I had one small area I needed to touch after my buddy leaned his sandy kayak against the side (people must have been stepping on it to get up on my tramp - arrrgh!) but I had it back to new in no time. Highly recommended. Again, I user Barkeeper's Friend followed by three coats of Zep Wet Look Floor Finish. It's essentially a clear coat that can be removed with stripper if it ever begins to fail.
Another option is Newgalss2.
http://www.newglass2.com/cgi-bin/cp-app.cgi
