Please Safety Wire Your Shackles AND Do It Correctly
6 Users
(@leeboweffect)
Here's my latest WTF moment/find.
Coated AWG 14 solid copper wire as safety wire. Please do not do this. Yes, maybe in a pinch temporarily, but not as a permanent installation. At least who ever did this had safety wire holes in the shackle pin heads and knew that backout restraint was necessary. Many of the shackles I come across these days don't have the holes and you must drill them yourself (yes, even the name brand stuff). I see many folks these days with no safety wire anywhere and I stay as far away from them as possible for obvious reasons. Here is the correct wire (you can buy it many other places) and technique. I use 0.032" diameter wire some folks use 0.041" diameter.
https://www.fastenal.com/products/details/0985093
https://youtu.be/7Xck44xYeaE
Posted : August 31, 2021 9:10 am
(@waiex191)
My H16 came with electrical wire everywhere, including in place of a ring or cotter pin on pins that hold the shrouds. Pretty scary. That's all gone now.
Here is another source - Aircraft Spruce. You can buy a 1-lb can like in the fastenal link or they also offer 25' sections for not much money. You could get 25' of .032 and .041 for $2.50 plus postage.
https://www.aircraftspruce.com/catalog/appages/safetywire2.php?clickkey=4386
Posted : August 31, 2021 9:29 am
(@Dogboy)
Maybe I’ll get slammed for this one, but for the past several years I have just been using a plastic zip tie through the hole in the shackle pin and secured to the body of the shackle. It seems to work totally fine and is cleaner/easier to remove when I take the shrouds off at the end of the season. I typically back it up with a coating of blue (medium strength) Loctite on the threads and a nice firm tightening of the pin with a pair of pliers.
Steve M.
Posted : August 31, 2021 10:35 am
Andres Chianale
(@Andinista)
Dogboy wrote: Maybe I’ll get slammed for this one, but for the past several years I have just been using a plastic zip tie through the hole in the shackle pin and secured to the body of the shackle. It seems to work totally fine and is cleaner/easier to remove when I take the shrouds off at the end of the season. I typically back it up with a coating of blue (medium strength) Loctite on the threads and a nice firm tightening of the pin with a pair of pliers.
I do that too, and the last sentence is the most important, the plastic cable tie is more for peace of mind.
Posted : August 31, 2021 10:52 am
(@Edchris177)
Captain
Decades ago, when wandering through the hangar, I would talk with AME’s & was shown how to use those specialized pliers. I still have a roll of the SS wire.
I don’t believe that is necessary, or even effective on a beach cat. The copper wire was done in a bit of a mess, but a single loop twisted is quite sufficient, the Nacra manual says you can use a bit of string on the Diamond wire turnbuckles.
Aircraft exhibit much greater torques & vibration. If I were helming a Vendee Globe boat I might.
There is a major difference between what that AME was doing with the propeller bolts & our rigging. One word- TORQUE.
Those bolts might experience a torque, which might undo them, leading to catastrophic failure. Our shrouds, & most of the rigging is secured by pins, which are under shear load- there is no torque trying to undo them. The safety required is a physical means of preventing the pin from sliding out.
Usually this is prevented by the double shear load on the pin, however, if the rigging goes slack, the pin could move. A bent cotter pin or ring ding prevents the pin from sliding out.
My Diamond wires are cotter pinned, everything else is ring dinged, with the ring folded over, then taped to prevent being snagged.
As for shackles that employ a threaded pin, you will notice a small, but significant difference between these pins & a bolt.
When you do them up, you will feel the thread get snug, then turning a bit more, (with pliers), it feels like they go “over Center”. This is the locking mechanism.
For what it’s worth, I asked the guy who built my new rigging about safety locking them.
He won a gold medal,
Sailing a Tornado,
At the Olympics.
He said...”not required, they won’t come undone.”
I generally tape, in a figure 8, around the flat head of the pin, but I would never go to the trouble of using lock wire pliers. Lock wire has a nasty habit of forming meat hooks. I would also never bother with blue loctite , unless maybe I was a Round the world ocean racer.
As Dog boy said, a zip tie is sufficient.
The only place I use lock wire is through the turn buckle on the Diamond wires, & to secure the steering U-joints on the Nacra tiller tie. The steering U joints was done on advice from a member here. I did it as a temporary solution...but it’s been 7 years now. It’s on my To-Do list, honest.
Posted : August 31, 2021 3:48 pm
jonathan162
(@jonathan162)
I'm with you on that. I have a little coil of SS lock wire in my kit "just because", but I've never actually used it. I tighten a little past finger-tight with a shackle key or pliers - whichever is handy - and it's never been a problem because there just isn't enough vibration. If you like it for "peace of mind", fill your boots, there's no harm in it. A ball of copper (whether tin-plated or not) is just dopey. And while I'm okay with plastic wire ties in spots (black, because they'll tolerate the UV), there's a special place in hell reserved for anyone who uses them, doesn't cut the tails off ABSOLUTELY FLUSH, and instead leaves a jagged end.
Edited by jonathan162 on Sep 03, 2021 - 10:26 AM.
Posted : September 3, 2021 4:25 am
(@leeboweffect)
jonathan162 wrote: I'm with you on that.
Yep, right out of the Hobie 16 manual (and every other Hobie manual I've ever seen). Mr. Alter knew what to do and it's proven a safe practice for decades. Not sure why anyone would say it's not necessary. They don't put holes in shackle pin heads for fun, it's for safety. Besides it just takes a minute and cost pennies.
Posted : September 3, 2021 12:52 pm
(@Edchris177)
Captain
That photo should be a lesson in how NOT to use lock wire.
No one with any experience in aviation would do such an amateur job.
That meat hook end is just waiting to stab holes in your sail, or your flesh.
Actually, holes in the pin are often used to attach a lanyard to prevent pin loss.
No harm in securing them, but lock wire pliers are an expensive solution, IIRC they were$100, thirty years ago, though maybe Chinese ones are cheaper today.
Posted : September 3, 2021 3:49 pm
