Nacra 18m2
10 Users
10.8 K Views
André
(@catmodding)
Hi Everyone,
Yesterday I came accross a Nacra 18m2 up for sale in my hometown, Amsterdam.
Never heard of a 18m2 Nacra so I browsed the web only to find it has 5.5 hulls,
lenght is 5.5 mtr (18 feet) beam is a stunning 3.25 mtr (10.7 feet) !! and it has
a main only.
I sailed my p 18-2 solo till late fall, and topspeed always was 19 knts, whatever I
tweaked , couldn't get it any faster and I want to go faster. I have the impression
the p 18-2 has a somewhat outdated hulldesign.
Will I be able to right the Nacra solo considering the beam?
I am a big guy 6.4 ft and 280 pnds but still ....... :-O
Pricing is very tempting, so has anyone sailed a Nacra 18m2 ?
Any information about the 18m2 is welcome.
Greetings, André
Edited by catmodding on Nov 30, 2010 - 10:26 AM.
P 18-2
Posted : November 30, 2010 6:22 am
Scott Finley
(@smfinley)
I believe the 18m2 was designed to be a single handed race boat. Never sailed one, but I bet with your size you could right solo with a little effort, practice and a few tricks.
Hobie 18M in Chicago
Posted : November 30, 2010 9:46 am
erice
(@erice)
my nacra 5.2 carries 19.6m2 of sail if you add jib to main
an 18square is going to have a taller mast with a more efficient sail but it is probably going to have less sail area than your prindle
the extra width is going to give your weight more righting moment which should help make up for the shorter hulls but you still might not get past 19knots, you might need more sail and length for that, something like a nacra 5.8 should do it
the extra width will also make the boat a little slower in light air as the windward hull will be more "sticky"
imho the 18m2 class is dead for a reason...
1982 nacra 5.2
2009 weta
Posted : November 30, 2010 8:48 pm
halfcat
(@halfcat)
The 18sm is fast with a new main (square top, Elliot/Patterson) and well rigged. Takes some practice to get to top of potential. usually out sails a F18 upwind but is slower downwind. If you add a spinnaker (Nacra sells a kit or you can add one yourself -F18 kit would work) it's faster downwind too. If you seal the mast you should not ever have a problem righting the boat yourself. Some of the older boats have stress cracks and need to be reinforced from time to time but can be competitive if sailed well. Portsmouth #'s are wrong since there are not a lot of them, shouldn't give time(without spinnaker) to an a-cat since it's a heavier boat even given the SA delta.
Posted : December 1, 2010 6:31 am
André
(@catmodding)
Thank you guys for the replies,
First of all, it's an original , it carries the 18m2 sign in its main. Comes with a extra wide cat-track.
erice wrote: my nacra 5.2 carries 19.6m2 of sail if you add jib to main
@ Erice
it has the longer mast and original mainsail, hulls are 5.5 . My p18-2 has more sail-area but can't break the 20 knt barrier.
Catmodding is my hobby, so I was wondering to add a selftacking jib and a spinnaker on it.
Extra width means more sail up and trimmed right for the desired speed.
Major reason of my post is to discover the minor points of the design, like cracks and other difficulties.
5.5 mtr is 18Ft in my opinion, and just about the size I can handle solo getting the cat in and out of the water.
Also my marina will charge me more above 18Ft.
I am sailing on budget, so carbon A cats are out of the question.
halfcat wrote: The 18sm is fast with a new main (square top, Elliot/Patterson) and well rigged. Takes some practice to get to top of potential. usually out sails a F18 upwind but is slower downwind. If you add a spinnaker (Nacra sells a kit or you can add one yourself -F18 kit would work) it's faster downwind too. If you seal the mast you should not ever have a problem righting the boat yourself. Some of the older boats have stress cracks and need to be reinforced from time to time but can be competitive if sailed well. Portsmouth #'s are wrong since there are not a lot of them, shouldn't give time(without spinnaker) to an a-cat since it's a heavier boat even given the SA delta.
@ halfcat
will put a spinnaker on it, if I get it.....
What about stress cracks and where to look for them ?
In Europe we use the Texel-rating yardstick, its not for me though.
As a sound-engineer working theatershows, my weekend is mondays
till wednessday. Main reason I sail solo and no reggata's, but speed
is a challenge.
regards, André
P 18-2
Posted : December 1, 2010 2:08 pm
halfcat
(@halfcat)
Stress cracks can be anywhere, a lot depends on how carefully they've been taken care of. These boats were built to be light, some of the initial ones may have been a little too light but I don't have any hull numbers/years that I can point to, only observations from some people that have sailed in the class for a long time. We have probably the biggest fleet anywhere of Nacra 18s in NC, these guys chose the boat as a fleet and maintained a large number for many years but as cycles usually go the new trend is A-Cats. I would check the seams on the bottom of the hulls and the holes where the bolts connect that hold the straps for the crossbeams, these holes seem to crack and give up over time. The deck where the skipper sits to go out onto the trap is also where the hulls seem to be a little soft/under built, often resulting in leaking. Most of the boats around here have had a lot of inspection ports added and these ALWAYS leak.
I had a Nacra 18sqm and rebuilt the hulls and then sold it, my long term goal is to use an A-cat as a base and build an 18sqm from the hulls, 11' wide and a carbon mast, probably nacra 20 section and a spinnaker. Under Portsmouth we have an established rating for Nacra 18sq over 350 lbs and under, I think an A-Cat/18sqm w/ spinnaker could weigh about 225. I've been watching Whites Dragon on facebook and I like the work he did to the a-cat to reinforce the hulls and move the stress of the shrouds to the "frame" that he made w/ the crossbeams and the longitudinal additions, I think my A-Cat/18sqm would use a similar approach. My biggest concern w/ the A-cat platform is having enough buoyancy in waves to keep the boat moving since I'm bigger 100+kg and adding 40-50 lbs in reinforcing, crossbeams, more sail, more mast, spinnaker, etc may cause a lot of wave drag and slow the boat.
Posted : December 2, 2010 3:12 am
André
(@catmodding)
Last weekend the owner told my it was sold....
Yesterday he called me that deal went bad.
So , next thursday we have a meeting to inspect
the 18m2, curious I am.
Thanks, Halfcat for the helpfull information, will
keep them in mind next thursday
Greetings, Andre
P 18-2
Posted : December 14, 2010 11:10 am
André
(@catmodding)
Amsterdam, the Netherlands is covered in 7-8 inches of snow, traffic jams everywhere till late in
the evening. Very rare in our country.
Rescheduled appointment till most of the snow is gone.
Grtz, A
P 18-2
Posted : December 17, 2010 1:39 pm
(@damonadmin)
Admin
A lot of the 18 Squares that are found were kind of home-built following the class rules, but here is a brochure on the factory Nacra 18 Square.
Posted : December 17, 2010 2:48 pm
erice
(@erice)
yup, the black ice is causing chaos in cities that usually don't get it. pity this audi owner. from a few days ago in geneva
http://www.youtube.com/watch?v=sKxy5Vst7Mo
Edited by erice on Dec 18, 2010 - 05:59 PM.
1982 nacra 5.2
2009 weta
Posted : December 18, 2010 1:56 pm
André
(@catmodding)
Deal went bad, worn mainsail. worn tramp. Think I am gonna invest in a new tramp
on my P 18-8 and also put a spi pole on it.
Today I'm going to pick up my dry-suit wich I had made after watching the P16 icebreaker
video. Though to get a suit in my size.
Temperatures are around 40's overhere. Hopefully I am sailing next month with my new suit.
A.
P 18-2
Posted : February 7, 2011 4:09 pm
André
(@catmodding)
sorry that's a P 18-2 ......
P 18-2
Posted : February 7, 2011 4:11 pm
 18sq
(@18sq)
Newby
Think I bought it, André...
I'm really curious to sail it, but I'm gonna wait till our lake is defrosted... ^^
Ok, rather till April or so. Then I'll tell you about my speed (110 kilo, 197cm 😆 )...
maybee it'll need a spinnaker 😉
Posted : February 13, 2011 9:20 am
erice
(@erice)
congrats on the new boat
think we would probably all love to see some pics when you get her sailing
never seen 1 in the flesh myself but from the pics some of them seem to have had flexy tapering masts, unlike the 5.2 for example that has a constant sized extrusion
if it does have a tapering mast do your research carefully before mounting a spin
1982 nacra 5.2
2009 weta
Posted : February 13, 2011 11:48 am
André
(@catmodding)
Congrats on your new cat, 18 sqm, if you fill in your personals in the members panel we can have
chat and maybe a meeting to see how its sailing on our almost defrosted lake.
Next tuesday I'm gonna put the mast up and set the trampoline. Just waiting for a good dry-suit
coming my way.
I am really curious how the cat sails!
Grtz, André
P 18-2
Posted : February 13, 2011 4:40 pm
(@daniel_t)
I know I'm late to the party here, but just an FYI:
Portsmouth Yardstick for the two boats in question:
18m2 (Cat.2 incl 11' N5.5) -- 67.2
Prindle 18-2 -- 69.1
So the 18m2 should be just a hair faster than the Prindle.
Posted : October 5, 2011 1:45 pm
 18sq
(@18sq)
Newby
At first: Sorry for my English.
I have not been out sailing so much this summer unfortunately and tested wind-conditions only from about 2bft to 5bft.
Allthoug Catstick- and Texelratings of the boat are very hard, it can't compete with -for example- modern A-cats. The 18sq was a lot slower when I sailed it at about 3 bft, maybee I could still improve the trim of the 18sq, but the difference was quite evident.
Untill now I even went faster with my recent Nacra 6.0 (18,5 kt compared to 17kt with the 18sq). But I have the feeling more is possible... (with 6bft 🙂 ). When the wind gets harder, the 18sq is a boat still nice to sail...
Maybee that the 18sq can go higher up to the wind than other boates is the main advantage - not the speed.
But I'll go on trying...
Edited by 18sq on Oct 06, 2011 - 10:23 AM.
Posted : October 6, 2011 3:23 am
André
(@catmodding)
18sq
Nice to see you on the forum again. Bin a while for me too. Do You sail on the ijselmeer lake in
the Netherlands? Would like to see the 18sqm. The fall is starting here quite rapidly, still like to go
out for a sail.
Managed 16.9 knts last Tuesday on the completely renovated P18-2 . Took the cat to France last summer,
Atlantic ocean 18.3 max speed there.
Speed is not the only reason sailing a cat, its a lot of fun to. The reason I started this post was the soloist in me
looking for a faster boat within a certain budget.
After the decision to renovate the prindle, I found the boat is a handful at topspeed sailing solo. Also the inexperience ( coming from 30 yrs monohull sailing) on my part did not help much .
I go out sailing as much as possibly and still discover new (downwind) tricky stuff, but I'm gonna keep my
precious P18-2 until she falls apart!
Still like to see your 18 Sqm and sail together
regards, A
P 18-2
Posted : October 6, 2011 8:36 am
(@klozhald)
Master Chief
catmodding,
Have you put foot straps at the after end of your hulls for that high speed downwind situation, and/or rigged a Hawaiian style righting line that you can hang onto downwind to stay aft? I am interested to see what works for others. At this point I am just using an adjustable trapeze but as I get the courage to stay out, I have difficulty doing it well. Any advice is appreciated.
Posted : October 6, 2011 6:06 pm
André
(@catmodding)
@ Bob,
Yes,I did put footstraps on the hulls behind the rear-beams. No extra lines to keep me on board, to dangerous in
my opinion. Also my trapeze-hook is one of the "open" type. On a downwind track I will not go out on the wire when the waves are high or choppy, I'm not that kind of hero yet, maybe in the future... Also have the adjustable trapeze.
At certain wind-angles on my hometown lake, the wind-force can go up to 5 Bf without developing any major waves,these are the moments I reach the speed mentioned.
Other than that I removed the 4-way jib system, it is to complicated when you're on you're own , it hurts my knees and ruins my expensive dry-suit. Gain in speed is minimal for what it brings on complexity on board.
Removed the second trapeze-wire for a even cleaner boat.
Did put the cleats on the sheet-blocks in the "up" position, difficult to cleat, easy to uncleat.
Will try to post some pics this weekend.
Regards, Andre
P 18-2
Posted : October 6, 2011 10:08 pm
(@klozhald)
Master Chief
Wow- Force 5 on smooth water???? I'm jealous! If I had read more carefully, I would have realized that you are sailing single-handed. I understand not having the hands for the tiller, mainsheet and the righting line all at once. You have big huevos to use the open-type trap hook single-handed!
When you set your jib blocks to a static position (by eliminating the 4 way hardware), how far inboard of the hull did you put the blocks? I could see putting them 9 inches/23cm inboard and using the Barber Hauler to trim it out under heavy air and/or running off the wind. Have you found a better way?
Sheet in!
Posted : October 7, 2011 5:50 am
André
(@catmodding)
Yes, its fun to sail on smooth water, I live in Amsterdam, the Netherlands and keep my cat at Uitdam on the Markermeer. Its an old inland sea wich they closed with dykes in the early 1900's . There is a stretch about 10 Km long from Marken to Amsterdam where you can sail right behind the dyke, just far enough out to catch the wind but
not the waves with strong westerly winds, which are common overhere. You can check it out on googlemaps.
So, what are Huevos? Checked it out in a English dictionary and later found it is a Spanish word.....
I use an open hook because its safe and not to difficult to unhook in stressful situations, problems occur
while going in and out when the ring snaps loose. Solved this by knotting 1 meter of shockcord to the trapeze-ring and attached the cord to the trapeze-wire with a couple of tie-wraps glue and some tape. Did put a piece of gardenhose around it so there's no cords flying around and I can grab it without hurting myself . Now there is tension on the ring going in and out.
The jib-blocks are not in a static position , they are attached to the standard track on the p18-2. Moving the
blocks forward provides a bigger slot upwind in heavy weather.
I'm still thinking how to use the old bauberhaul-system to trim the jib in . It means al lot more of control-lines and being a soloist it hasnt come to me yet.
Since I did put a spi-pole on the 18-2 , and bought a second-hand spi from a F18 class, downwind sailing is more
than a handfull. I just leave the jib sheeted in and control the spi-sheet with one hand and the helm/mainsheet from
the other. Never think about jib settings downwind.
To be honest I never used the spi config above 2/3 Bf and have to figure out how to get the spi back in the snufferbag within seconds, but I am working on that.
So, soloing on a budget behind a dyke, fall is kicking in fast and I don't think there's a lot spinnaker reaching left.
With my dry-suit I'm gonna be sailing till the lake freezes over and let you know about downwind tweaking .
Regards, Andre
P 18-2
Posted : October 7, 2011 9:54 am
(@nl_expatriate)
than a handfull.
I've been following along and would love to see some set up pictures of this as well as some in action shots if you have them..
I just added a spi pole but only have a jib for it right now. I was wondering if it is even feasible if not usable. Light wind inland lake.
Posted : October 7, 2011 11:08 am
André
(@catmodding)
@ nl-expatriate
mine 18-2 is a Prindle 18-2, NOT a Nacra 18sqm !
Started this post because I was interested in Nacra 18sqm, that deal
went bad and I decided to give my Prindle 18-2 a complete overhaul.
Regards, A
P 18-2
Posted : October 7, 2011 11:52 am
(@Edchris177)
Captain
On the menu in all Spanish restaurants, eggs. In this case a substitute for another Spanish slang term, cojones...as in, Balls, man, you got big balls.
Posted : October 7, 2011 3:20 pm
(@klozhald)
Master Chief
Andre,
Don't be apologizing for your English- it is well done, and much better than my Netherlandic Hollands. And yes, I was admiring your courage (big huevos) about single-handing with that open trap hook. I have one too, and I make very sure my bungee is tight and in good shape before I sail, but I have a crew to come get me if (when) disaster strikes.
In other news, There are tuning sheets for the P18-2 for different points of sail that give settings for standing and running rigging. They were written by one of the most successful sail-making houses that also raced the 18-2. They are here: http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=178953 Who knows, you might find a go fast tweak in there somewhere.
A 10 km beam reach run that blows Force 5 over smooth water. That might just be enough to get me to ship my cat over the Atlantic! Don't I wish...
Sheet in!
Posted : October 7, 2011 6:04 pm
