Mast stepping and unstepping
19 Users
15.2 K Views
(@lucydog11)
Has anyone tried to step or unstep a Hobie 18 mast by putting the boat up on only one hull while it is on the beach?
Posted : July 2, 2014 8:51 am
(@fxloop)
I wouldn't do it that way - you'll likely snap off your mast base as the mast moves aft and the high hull starts to rotate down, twisting along the way. There's a guy on here who knows all to well how easy it is to snap it by lowering it the correct way 😉
If the mast height and/or weight is the issue, use a solo righting system and a winch on your mast support on the trailer, it works very well and is safe.
Posted : July 2, 2014 9:44 am
Dave Farmer
(@davefarmer)
Yeah, that mast base is quite intolerant of abuse. I build gin poles for most of my boats, pretty simple and cheap if you got any any stuff lying around. Safe and fairly Quick to raise the mast solo. Pm me if you wish, I've got pics lying around.
Posted : July 2, 2014 11:12 am
(@bacho)
I think it would be more work to tip the boat on the beach (without mast) than it is to just step it. Momentum is key, don't stop once you start going up of you can help it.
Posted : July 2, 2014 12:29 pm
Hobie / E-Z mast stepper - (gin pole) http://static.hobiecat.com/item_attachments/3151z52.pdf
Posted : July 3, 2014 3:53 am
(@Dogboy)
Would be WAY harder than just stepping the mast the normal way - would likely require at least four people and almost certainly end in disaster.
The best/easiest/safest way to step the mast is to put the boat on the ground with beach wheels under the rear crossbar (so the bow is tipped slightly down). Have one person hold the mast on their shoulder near the mast tang. The other person then stands on the tramp and grabs the mast and raises it. If you are not strong enough to do the lift yourself, then have the person that was holding the mast at the tang come up on the tramp and lift with two people. Raising the mast with the boat on the ground gives you a more stable platform than on the trailer and it also allows you to start with the mast at a higher angle relative to the boat, so you don't have to bend over as far to pick the mast up.
Steve M.
Posted : July 3, 2014 4:27 am
(@goldwingnut)
How long is the pole on the E-Z mast stepper?
Posted : July 3, 2014 8:07 am
Dave Farmer
(@davefarmer)
Not sure of the length of the pole on the EZ, but it's really convenient if the pole length is equal to the distance between the front of the mast and the intersection of the bridle wires and the forestay, so that when the mast is up, the forestay can be pinned without having to remove the gin pole. Once it's secure you can remove the device.
Pole length is less critical if you're using the trailer winch. My gin poles have a trailer winch mounted to the pole near the mast, with the line/cable running to a strong block at the pole tip. The line has a hook or shackle that connected to the trailer tongue just below the bridle intersection, or can connect to the ends of the bridle wires if the boat is on the ground. At the end of the pole I fashion a slot that the forestay can knock into above the thimble at the forestay's end, or a hook or shackle to connect to the forestay. The slot arrangement allows the thimble to be free to pin to the bridle wires without having to secure the mast temporarily with the jib halyard, while removing the gin pole.
There are two smallish lines from the end of the pole with snap hooks that connect to the ends of the main beam, to keep the pole tip in plane with the boat's centerline(and the mast). And of course, two trap wires are run to the beam ends as well to keep the mast in that plane.
The effort to build a gin pole will soon be forgotten as you become comfortable raising and lowering your mast safely and easily.
Posted : July 3, 2014 10:16 am
(@goldwingnut)
I didn't mean to hijack the thread but thanks davefarmer for the instructions. I work building things out of aluminum every day. Although I have figured out how to step the mast by myself a ginpole sounds like something I have to build. 😎
Posted : July 4, 2014 12:47 am
BrianCT
(@BrianCT)
I use a 6 foot step ladder to step my H18 mast. Connect the mast base and and shrouds while resting the upper mast on the top step of the ladder, which I locate maybe 10 feet behind the boat. At this point the helper is simply making sure the mast doesn't blow or slide off the ladder and break the hinge (I learned this the hard way!). Having the mast semi-raised like this makes it much easier to start the lifting process as you no longer have to "navigate" around/under the diamond wires. Once I get underneath the mast and begin lifting, my helper walks to the front and connects the forestay. I did it by myself once with the help of a line and a come-a-long but I won't be doing it again. 😆
Posted : July 4, 2014 8:47 am
(@Dogboy)
BrianCT wrote: I use a 6 foot step ladder to step my H18.
I have used a step ladder when raising the mast as well (on my H17). With the boat on the ground and the top of the mast supported by the ladder, raising the mast is a lot easier because you don't have to bend over nearly as far to pick up or put down the mast. It also makes lowering the mast considerably safer IMO because you don't need someone at the back of the boat to "catch" the mast, you just place the mast on the ladder and then they can walk over to grab the mast after it's safely down.
Steve M.
Posted : July 4, 2014 12:24 pm
(@fxloop)
I use this to get the mast on my H20 up and down. Bottom half speaker stand, top half PVC wrapped in pool noodle. Cheap, fast ( assembles in 30 secs ) and makes life easier. Walk mast back to the stand w helper, pin it, helper goes forward to winch mast while you keep it steady left to right - no need to lift, winch does all the work. Takes all of 4 mins to have mast stepped and pinned. No fuss.
Posted : July 4, 2014 12:42 pm
(@kernunnos)
Would a 2 piece Gin pole work better? As in a triangle? I have a bunch of aircraft aluminum tube 1 1/2 dia.
I was thinking to join both pieces at the top, a hook & loop system for the stay and winch....
My thinking is the triangle would be more stable.
Any opinions, I can step the mast quite easily myself...no wind, on the trailer however I added a winch to the fore mast stand.
Posted : July 4, 2014 2:46 pm
arch
 arch
(@arch)
here's a system i have for sale. this is the last one i have available.
http://www.thebeachcats.com/classifieds/catamaran-parts-for-sale/p13265-solo-mast-raising-systemfor-beach-cats.html
j
Posted : July 5, 2014 4:27 am
(@Edchris177)
Captain
Has anyone ever tried holding both trap wires, placing feet on the front beam & hiking out,(towards the bows), as the other person lifts the mast?
I didn't make that up, it's the technique shown in the Mystere Manual. They were assembling a 5.0XL.
I couldn't manage to create an album with the PDF file.
Posted : July 5, 2014 5:04 am
(@Dogboy)
Edchris177 wrote: Has anyone ever tried holding both trap wires, placing feet on the front beam & hiking out,(towards the bows), as the other person lifts the mast?
I've never done this, but I recall seeing it done once by some Tornado sailors. I guess it would work, but I could almost see that causing a problem as the mast gets towards the upright position, if the person hanging off the front is too heavy, it might actually cause the mast to slam forward.
I like the trick with the ladder (or other aft mast stand). I've done this before when solo stepping the mast on my H17 and it makes life a lot easier because you don't need to bend over nearly as far to pick the mast up - it starts out a a relatively comfortable height. It's also nice when lowering the mast because you don't need someone there to "catch" the mast as it comes down, so it's a lot safer (no matter how many times you tell people not to stand under the mast as it comes down, they always seem to want to put themselves under it).
Steve M.
Posted : July 6, 2014 3:39 am
(@Edchris177)
Captain
From the photos I saw it seemed that the person hiking back would just step off the beam to the ground as the mast came vertical, then hold it there with the trap lines.
The other person was still on the tramp, holding the mast, they could easily control its movement once near vertical.
Tornado is a tall stick, if it worked there, it should be doable for smaller boats.
Posted : July 6, 2014 4:01 am
(@kernunnos)
wouldn't the shrouds hold it from coming forward?
Posted : July 6, 2014 3:31 pm
(@Dogboy)
I didn't say it would fall forward - just slam forward, against the shrouds as the mast would be accelerating upward.
I have also seen people take a long line (like jib sheet) and tie it to the main halyard. Then one person grabs that line and walks out in front of the boat, pulling the mast up as they go with the other person standing on the tramp guiding the mast up. Once the mast is up, the person holding the line just stays put holding the mast up while the person that was on the tramp jumps down and pins the forestay. A lot of ways to achieve the same thing...
Steve M.
Posted : July 6, 2014 10:07 pm
I love it when we over-complicate things-
You can also just tie an extension line around a trap handle (or both) and not have to step/fall off a beam
if you have crew, why not have BOTH of you on the tramp, and walk the mast up
when it's up... one of you go pin it (or tie if off to your furler ring)
or throw a line around your forestay and have your crew help pull it up
OR trailer your boat the other way and after you secure the mast step/pin ... use the trailer yoke to hold your mast up (like the 10' ladder) - even better, back it down the shoreline and improve the angle/help
Edited by MN3 on Jul 07, 2014 - 11:29 AM.
Posted : July 7, 2014 3:30 am
(@the-renovator)
Mast stepping made easy
https://www.youtube.com/watch?v=DO4RxwvjKtM
but you do need a tilt trailer.... 😀
Posted : July 7, 2014 12:42 pm
(@Edchris177)
Captain
That's what I do on the 5.0, 5.7 & the 33' stik on the 6XL.
I was looking through the Mystere manual, & saw the idea of hiking back while holding trap lines. I just wondered if anyone had used it, & if it worked.
You guys, with that few feet of steep beach have it the best. Watching Dave drop his mast solo, without much work must make many trailer sailors green with envy.
Edited by Edchris177 on Jul 07, 2014 - 08:10 PM.
Posted : July 7, 2014 2:10 pm
(@mgoltsman)
I don't really have a problem physically raising the mast by myself on my P16 with only a mast hinge - except when I get a side stay caught on a transom or a trailer wheel cover, but I am too much of a chicken to walk off the tramp holding the forestay with one hand then catch the bridle and snap it on. I have vivid images of somehow losing my grip on the forestay either while hopping off the tramp and causing one or more unfortunate events within the 30 ft. radius of the boat (or within a 30 ft. radius about 1 rad arc behind the boat, to be more precise), or - if I am VERY lucky - only ruining the mast.
I almost found a solution - my trailer has a mechanical winch attached from it's jet-ski days, and I can raise the mast using the winch cable going through the mast mount cradle. But the P16 mast hinge is only meant to provide a very basic guidance and positioning to the mast base, not enforce the vertical rotation of the mast. So, I still need a person on the tramp guiding the mast even if they don't really need to provide any effort (winch does the lifting). It's not a problem now since I would not go out solo anyway, what with about 3 hrs total sailing experience. But here is the system that I intend to shamelessly copy once I am brave enough to try going solo and not too cheap to splurge $100ish on an electric winch:
http://youtu.be/sdFm_9Q09ac
Posted : July 7, 2014 5:39 pm
i believe it's only 31' (based on the stock 6.0, and i didn't think/know the xl had a taller stick)
please let me know if i was wrong -
Posted : July 8, 2014 5:31 am
(@kevinbatchelor)
Here is how i raise the mast solo. https://www.youtube.com/watch?v=733z8c7EUJ8
Edited by kevinbatchelor on Jul 09, 2014 - 01:45 PM.
Posted : July 9, 2014 7:44 am
(@Edchris177)
Captain
You might be right.
I just put the mast back up, (took it down to change furlers), but didn't measure it. Hopefully it won't come down again til end of season.
I have one basement room at the cottage that is 31', & it won't fit on the ceiling rack with the others.
There is a Hobie Bob at the top, that might make it longer than 31'.
I'll measure it next time it comes down.
Posted : July 10, 2014 9:39 am
you can run a 31' line up the halyard and see (maybe add a foot for the knot)
for sure it adds height
Edited by MN3 on Jul 11, 2014 - 07:29 AM.
Posted : July 11, 2014 1:28 am
Dave Farmer
(@davefarmer)
I just posted some pics of a few gin poles I've constructed over time.
Edited by davefarmer on Jul 12, 2014 - 06:18 PM.
Posted : July 11, 2014 3:01 pm
(@jlooby)
Hi all,
Here's my solo mast raising video by request.
https://youtu.be/W4cLtC26aRM
James
Bimare F18 HT
Farrier F25C
Posted : May 15, 2015 1:26 pm
(@goodsailing)
Just a non tilt trailer will do for this one I made using your boom. Then follow ez hobie mast stepper manual instructions. Be sure to place side guidelines under the trailer that pull trap wires away from boat to guide mast sway. There's a pic of actual gooseneck fitting in my album. I don't see how anyone can pin the bridle without mechanical tension. I use the winch on trailer and pinning is easy.
Posted : May 16, 2015 3:58 am
Page 1 / 2
