looking for a better way to fix a leak in a board well
9 Users
I have a small leak in my centerboard well (usual spot for leaks)
it is in a spot that is gonna be really hard to access - requiring sanding via a 4' extension and even then, it is on a curved surface that i am not sure how i can actually scuff up well
i can just about reach the hole from under that boat but it's tough - and i don't really want to sand above my head for extended periods of time
the biggest issue is post cure - the epoxy is gonna be reallllll tough to smooth and it's in a tight fitting spot on the board well= any edge is gonna skuff up and possibly damage the board when it's moved into spot
any product like a 2 part pool epoxy i can reliable stuff in there that will last for years?
Posted : July 16, 2019 3:10 am
samc99us
(@samc99us)
These are tough problems, tight spots in the back of a board well..
The best approach I've found is to mix some G/Flex 655, and place in the known leaking area with a bent acid brush attached to a dowel rod. Apply vacuum to the hull if you are really concerned, it should suck the epoxy into the area.
The other option if its a really thin hole is the same approach but with raw West Systems or other epoxy. I find the G/flex a good option in board trunks though because its a tiny bit flexible and normally the trunks themselves are super thin glass that tends to flex a bit under load.
Posted : July 16, 2019 5:07 am
samc99us
(@samc99us)
Standard (unfilled) G/Flex 650 might be perfect...the thing with the 655 is it is filled just enough to prevent runs and sags which is why its pretty perfect for a repair on a vertical surface where a run results in nicked boards...
Posted : July 16, 2019 5:13 am
Good info Sam thanks
any suggestions for a cheap vacuum unit?
Posted : July 16, 2019 5:25 am
Peter knapp
(@pknapp66)
Do you have drain plugs in your hulls? I used a small shop vac on one of my H18's that had a leak in a seam
in the dagger well. Worked good to draw in the epoxy. Just had someone stick the vacuum hose over the drain
hole while I applied epoxy. Went quick and we did not maintain any vacuum after the epoxy was drawn in.
Thinking out loud you could install a vacuum gauge in a spare hatch cover to monitor how much you have in the hull.
Edited by pknapp66 on Jul 16, 2019 - 11:47 AM.
H18m
p16
Venture15
Posted : July 16, 2019 5:45 am
i have drain plugs - used them to fill the hull w 15psi this weekend to find the holes (with soapy water)
i have a small shop vac - was worried it might suck "too much" (haha)
Posted : July 16, 2019 5:56 am
(@Dogboy)
No way to internally access the hull? Getting a glass patch on the inside is going to be a much more reliable and permanent solution than using straight epoxy on the outside.
How bad is the leak? If you’re only talking a small amount, might be better off just leaving it alone and living with it (sponge out through an access port periodically if it really bothers you).
And on another note, wholy crap, 15PSI? I’ve detected leaks in boats by just blowing into the drain plug with my mouth. Surprized you did not damage the boat with that much pressure.
Steve M.
Posted : July 16, 2019 6:36 am
Peter knapp
(@pknapp66)
I used the shop vac in reverse to find the leak with soapy water. You can remove the vac and kinda gauge
how much you are pressurizing the hull by the air coming back out of the drain plug.
H18m
p16
Venture15
Posted : July 16, 2019 7:10 am
not without cutting an access hole on the bottom of my inner hull - that is not a good solution to me
couple gallons after 7 hours of sailing = too much for my happiness + if it gets worse ...
it wasn't 15psi of pressure in the hull - that was the setting on the compressor
i used a wet cloth around the nozzle and it certainly was not a tight fit
also 4 small holes in my deck prevent any real pressure (turning blocks for the centerboard bungee that were removed) - but noted: it doesn't take a ton of pressure to blow bubbles in soapy water
Posted : July 16, 2019 7:24 am
(@klozhald)
Master Chief
There was a three way puncture in my Prindle centerboard well from a rock that got wedged inside. It was past my fingers up from the bottom. I laid the cat on its side, tied to the fence, so that the injury was facing up. I used paint stir sticks with sandpaper glued to them to rough up the area. Using Marine Tex, which is thick to go on and dries very hard, I applied it with another paint stir stick. A strong flashlight helped me make sure I got it as smooth as possible, then more sanding to keep it from scratching the centerboard.
My $0.02...
YMMV
Good luck!
Posted : July 16, 2019 7:42 am
thanks for all the input
I have used wax paper on repairs before . - just as the epoxy or gel-coat kicks off i add the wax paper and smooth it out with my hand (or tool) - just not sure i can access this spot like this
Bob, why did you tie your cat to the fence? afraid it might get loose? 🙂
Posted : July 16, 2019 8:05 am
(@klozhald)
Master Chief
MN3 wrote: Bob, why did you tie your cat to the fence? afraid it might get loose? 🙂
Truth be told, it has gotten away from me many times, but not so much in the back yard. I was taking no chances though!
Posted : July 16, 2019 8:31 am
(@nohuhu)
Quote
Roger, Roger! 😆
Any possibility that wax paper or sandpaper sheets could be taped to the centerboard (or a spare), to correctly shape and smooth this area?
It might help create the right clearance, Clarence...
Posted : July 16, 2019 9:06 am
Surely you can't be serious
PS superb idea! -
Posted : July 16, 2019 9:34 am
(@traphappy)
I will offer two ideas that are probably both bad... But hey, who knows. First bad idea: Stand boat with bows up (yeah, easy to do, lol), dry thoroughly, sand, clean, and allow West System 105 to flow into gap. Second bad idea: dry thoroughly, sand, clean, smear West System 610 into the back of board well, build up the back edge of the daggerboard with tape, lube the hell out of it, then slide into the well. Hope you can get the board out. If you can get it out easily, then you'll be in the clear. Very important to evenly apply the tape so it slides out later.
Edited by traphappy on Jul 16, 2019 - 04:41 PM.
Posted : July 16, 2019 9:40 am
it's not in the "back" of the well
it is on the side (towards the inside of the boat)
looking down the well it is about 4" above the bottom lip (which has a gasket on it)
it is in a curved area of the well (i assume these curves are there for added strenght - the well walls are crazy thin like Sam mentioned above)
the curve area has a "bowl" shape to it (think of a 1/2 baseball) and it is inside the curve - that is where the real challenge is to sanding it is out of reach and in a spot that a flat item wont be able to get to
This image is looking down - the yellow strip in the middle is the gasket with a bunch of soap suds on it (this is from a phone video i shot while checking for leaks)
Posted : July 16, 2019 9:53 am
(@nohuhu)
Will the area accomodate a small repair patch?
Posted : July 16, 2019 10:38 am
i doubt it - if i can put that patch there i could put glass
the issue is really sanding it down afterwords
Posted : July 16, 2019 10:57 am
(@traphappy)
Why not just do the repair, lube up the board, and put it in place? If lubed it should come out without issue.
Posted : July 16, 2019 11:34 am
samc99us
(@samc99us)
Ah yes. I've done this repair on the beach, but on an Infusion Mk. 2 which has more room to work I think than what you have there. Tip boat on its side and work from the bottom with the same technique I mentioned. I would try and get glass in there if possible, and traphappy's suggestion of a waxed up board is a good one.
Posted : July 17, 2019 2:47 am
traphappy wrote: Why not just do the repair, lube up the board, and put it in place? If lubed it should come out without issue.
the hole is not on the wall where it would touch the board
it is inside a recess just is inside the lip.
look at the pic again : instead of looking at the arrow at the bottom of the well (where the leak is) look at the top of the well, on the left - it's the exact same shape
i don't think a patch is the right call because the patch would be almost impossible to get in the exact right location and if it was hanging outside the recess at all - it will scratch up the board
I am tempted to use 2 part pool epoxy - it stays flexible and can last for a very long time and is a 4 minute job (just mix it and smoosh it into the hole)
But i know the right way is to flip, and add some vacuum
thanks all!
Edited by MN3 on Jul 17, 2019 - 09:56 AM.
Posted : July 17, 2019 3:53 am
MillCreek
(@MillCreek)
MN3 wrote: i doubt it - if i can put that patch there i could put glass
Andrew
What about the use of a rat tail file to sand it down? Round Rat Tail Diamond Needle Files 10-Inch Round Shape 180#
by NICELEC Industrial
5.0 out of 5 stars 1 customer review
Price: $9.36 & FREE Shipping
Not easy to break
Grindable steel hardness metal, high work efficiency
› See more product details
New (1) from $9.36 & FREE shipping.
They come in different sizes, lengths and coarseness.
Forrest
Posted : July 17, 2019 5:06 am
MillCreek
(@MillCreek)
Or use a wielding rod with a Dremel barrel sander head on the end. Use the Dremal for power and reach down and sand it that way
Posted : July 17, 2019 5:10 am
HI Forrest - thanks for the input
i have round files that are pretty similar to the rat tail ones you show -
as per the dremel ... i am a little hesitant to put a power tool in there ... where i can't see - i am sure it could be done but i am sure i could screw that up too... the walls are really thin in spots and it would be tough to feather any sanding without enlarging the hole (i think)
i am gonna try to sans power tools but thanks for the tip if i need to get some powersanding in there
Edited by MN3 on Jul 17, 2019 - 02:12 PM.
Posted : July 17, 2019 8:11 am
samc99us
(@samc99us)
Tip the boat on its side. Not too bad with a second person. Then you will likely be able to get in there with a hand and sandpaper. I could on the Infusion trunk, similar location, this is the Mk. 2 trunk that is very narrow. Scuff the trunk, wet out a piece of 6oz fiberglass, guide into place with sticks as necessary. Let cure and go sailing.
I say all this because the centerboard doesn't contact that location per your description and 6oz cloth is 0.010" thick, so won't change the contact either. Brushing G/Flex in will likely work just as well, but you have more control with 6oz cloth in terms of wet out and you can let tack up before installation.
I did the same thing but used a tube of UV cure epoxy in addition to the fiberglass: https://www.solarez.com/product/solarez-extreme-3-5-oz-tube/
Amazon carries it as well. This was an on the beach repair in the Florida 300 and it held for the next 200 miles so...
Posted : July 17, 2019 10:27 am
(@traphappy)
This is how we fixed a similar leak in the side of P18-2 trunk. It was a bit easier because it was at the joint of the hull and trunk, so easier access. G-flex and cloth were easy to work with when boat was on its side.
Posted : July 17, 2019 10:36 am
MillCreek
(@MillCreek)
MN3 wrote: HI Forrest - thanks for the input
i am gonna try to sans power tools but thanks for the tip if i need to get some powersanding in thereEdited by MN3 on Jul 17, 2019 - 02:12 PM.
Andrew,
Some dremels offer flex cables about 18-20" long This way the sander stays outside and you sand with the cable and just head. Think of a dentist. Check Walmart for them or hobby shop. I had to grind out the glue on carpet in my well to replace the padding Dusty, but works well.
Good luck
Forrest
Posted : July 18, 2019 4:02 am
flex cables
Good idea
i see walmart has these - something . tells me they have this connected wrong :mischuge:
Posted : July 18, 2019 4:19 am
samc99us
(@samc99us)
Nope, that image shows the tool rigged correctly. It isn't that much smaller than a regular dremel.
I recently saw a Ryobi tool that is very similar, as they made it compatible with their existing lithium drill batteries so had to go to a remote tool head.
Honestly though I think you are overthinking the job...a piece of 80 grit sandpaper is enough to scuff for adhesion of a fiberglass patch.
Edited by samc99us on Jul 18, 2019 - 11:48 AM.
Posted : July 18, 2019 4:41 am
(@randii)
I feel for your small clearances. I have a slight leak in a Tennant T9 dagger well... and I can get my hand in there pretty well, since the boards are WAY bigger. The other well is even more entertaining, as there is a jam that no longer allows full insertion of the dagger. Fun.
The better prepared your surfaces are, the better the bond will be. Pre-scuff, and then wipe and irrigate the area with a solvent friendly to whatever adhesive you plan to use (taking care of any foam it may contact)... and leave a fan blowing to clear that solvent.
Use gravity to your best advantage, dunno about the vacuum unless you've got good control over where the epoxy flows when it pulls through. Peelply might help contain the epoxy, but it can't be manipulated/stretched/formed like 'glass... so definitely dry-fit.
Try to patch from outside AND inside, as well... ideally, one within the cure time of the other so that you've basically got an hourglass patch larger on both ends (convoluted as the inside may be).
Post up an update when you're done!
Randii
Posted : September 19, 2019 7:59 am
