Loading cat onto cat trax
bfoxg8r1
(@bfoxg8r1)
Hello there,
I store my cat, Nacra 5.2, on a sandy lakefront beach. I've always drug it to the water.
I recently purchased a set of cat trax to make this easier. Is there an easy way to get the cat onto the trax? Sometimes I single hand it. Any tips or trick would be appreciated.
Posted : May 24, 2012 6:31 am
Dustin Finlinson
(@Quarath)
Master Chief
What I do when i need to move it by myself, and that happens a lot, is I position the wheels in front of the hulls and lift one side a little and push that side in a bit. I kind of stand in front of the axel so it can't move much and move to the other side and do the same thing. I just kind of walk it back a foot or so at a time. until they are under the shrouds. Then loop the ropes or tie them in place.
If you don't have cradles make something like this to help it stay in place.
Dustin
Magna, UT
Prindle 18
Posted : May 24, 2012 7:06 am
(@klozhald)
Master Chief
Roll the trax up to the transoms, and lift the hull so that you can roll the trax under the rear crossbar. Move up to the crossbar and lift it so that you can push the trax under with your foot as far as you can on both sides. You want the trax right under the side stays. If you need to, walk around front and lift the hulls to slide them back on the trax. Once it is in position, tie the lines from the trax tightly around the side stays. Grab a hull front and head to the water.
Posted : May 24, 2012 7:13 am
presto13031
(@presto13031)
drag it to the water, sail the crap outta the boat, when you come back stop short of the beach and float the boat onto the trax
Posted : May 24, 2012 9:14 am
(@daniel_t)
And another method... Make sure the lines on the trax are long enough to go from the bow to the shrouds. Lift one bow and push the trax under it, tie it off on the shroud so it can't slide back out again. Then do it to the other side. Then back and fourth until the trax are in the right position.
Most of the time, I recruit some random beach goer. I lift the bows and she (usually I recruit 'shes') pushes the wheels in place.
Posted : May 24, 2012 12:35 pm
