Ideas for carrying a spin pole when trailering
8 Users
(@lakewateree)
Having trouble with where to put my spin pole when trailering my boat. I have a Hobie sail tube on the trailer but it's 2-3ft too short. A friend suggested adding an extension to the tube but I don't want to cut it plus I would then need something else for my sails. I've put it in the back of my truck, but it had to ride from corner to corner and stuck out over the side of the truck. Easy solution would be a nice new sail box, but don't have the cash for a new box. How do some of you carry your poles? I'd like to find a used one...
Posted : December 22, 2011 8:55 am
(@bacho)
Mine is strapped to the boat for now. Would your sails not fit in the tube with the pole in there as well. A bulkhead fitting would keep all of the water out.
Posted : December 22, 2011 10:09 am
Dustin Finlinson
(@Quarath)
Master Chief
Get a long enough PVC(or ABS) pipe that it will fit in. Cut a small hole in one end of the sail box for one end of the PVP pipe to stick out from the sail box. Put a cap on the end that sticks out. have the rest inside the sailbox. Insert into pipe in the sailbox and will will hang out the end inside the pipe. Seal the hole around the pipe.
Dustin
Magna, UT
Prindle 18
Posted : December 22, 2011 10:31 am
(@lakewateree)
If I add a piece of PVC to my Hobie tube then I won't be able to put my sails in it, so I'm back to needing another box. There isn't a whole lot of room in that tube..
Posted : December 22, 2011 1:33 pm
Rider_55
(@Rider_55)
Just mount a pvc tube to the trailer with a solid cap on one end and a threaded cap on the other using u bolts or cariage bolts with plates both inside the tube and on teh back side of the mounting point.
I have a total of 4 PVC tubes on my trailer. 1 6" and 1 4" on each side of the trailer just inside the wheel wells. The big tubes hold main, jib and boom, and the small tubes hold my ruder cross member (for long trips where rudder assembly is disassembles) tiller extension, and the axle for my beach wheels.
One peice of advice is to keep the open able end to the front of the trailer just in case the cap comes off your equipment won't scatter down the road.
Jeremy
Busted 1981 Prindle 18
Central Arkansas
Posted : December 23, 2011 3:29 am
(@bacho)
His snuffer is too big for that
Posted : December 23, 2011 4:25 am
Rider_55
(@Rider_55)
Sorry. I have spent too much time crewing on a mono this fall where the spinnaker pole is a whole different animal.
Would it be possible to mount a pipe big enough for the pole and cut a grove to accommodate the snuffer ring? Back half of tube remains solid, front half has a grove cut from top or side. You could even a a "T" where the ring rides to provide some lateral support if necessary.
Jeremy
Central Arkansas
Posted : December 23, 2011 5:02 am
(@lakewateree)
I think a box is going to be the best answer. Have started thinking about building one out of wood, but that would prob be way heavy and possibly not weather proof. I don't leave my stuff on the trailer so it might not matter as much. I really just need something for the trips to and from regattas...
Posted : December 23, 2011 5:31 am
(@manoverboard)
Newby
I just trailered my boat from Florida to Texas and the spin pole was bunjeed to the trailer. It made it back safely with no problems. Just an idea.
Posted : December 23, 2011 7:23 am
(@bacho)
I bet an HVAC fab shop could whip out a box like mine on the cheap. Galvanized sheet metal.
Posted : December 23, 2011 9:08 am
why not leave it on the boat? leave the spin bridals on, remove from the beam.. and lash it to your tramp/rails
most of us locals leave our pole rigged (100%) and since we trailer sterns to car (backwards) it doesn't get in our way... i hang a red flag off the end and at night i put a red light on it if it's gonna be dark out.
Posted : December 24, 2011 12:39 pm
Kenneth Boudreaux
(@KennyB)
Before you drill a hole in your Hobie box, you should consider selling it and upgrading to my fiberglass box (sailboxes.com). I make a fiberglass extension that bolts on the front of the box to accomodate a spin pole.
Kenny Boudreaux
www.sailboxes.com
Posted : December 25, 2011 12:32 am
(@lakewateree)
I dont plan on cutting my tube, its in near perfect condition. I looked at your boxes they are WAY nice, but unfortunately it would be out of my price range even selling my tube.
Posted : December 25, 2011 1:14 am
eragon
(@eragon)
this is how mine travels
Posted : December 25, 2011 4:30 pm
