Hobie 18 vs Fox, weight or skill?
Had a great day sailing my 84’ Hobie 18 against a 20’ Hobie Fox. We went back and forth a across the bay about a mile each way. The entire time I was either pulling away from the Fox or we were same pace. There were three guys on the Fox and me solo on the 18. After speaking with the Fox owner he had only been sailing few years where I have been for about 8, neither of us race.
Was it the weight slowing him down or technique? I expected him to blow right by me, was great my old 18 could hang with something that state of the art.
You don’t mention windspeed, but if you were solo, I’m gonna guess it was probably less than 15mph. In that case, having three on board definitely would have put the Fox at a disadvantage. Skill of course also plays a huge factor. All else being equal (crew weights and skill), the Fox would blow away a H18 any day of the week.
Steve M.
About 120-130 degrees TWA, 18-22kts of breeze and flat water with the kite up.
Even heavy, the Fox should kill the Hobie 18 on a standard W-L course. The Hobie 18 doesn't point nearly as well as a modern spinnaker cat and goes about 2 kts slower upwind, and downwind without the kite it gets killed.
At the same time, the Fox doesn't handle weight particularly well. It is essentially a scaled up A-Cat. Going 3 up on that boat would hinder it a bunch, and like bacho points out, they aren't all that fast on a reach anyway.
The Hobie 16, 18 vs. a modern F18 or 20 footer are reasonably close on a reach, though the new hull shapes in the F18 (semi-planing) and C-boards in the 20 footers make that contest pretty open and shut as well.
Thanks Sam, that's what i thought - (just wasn't sure if "TWA" was a variable in point of sail)
so a reach IS the modern F boat's fastest point
i am not sure i understand bacho's point nor relevance to the OP's question - however it did lead to interesting data
Edited by MN3 on Oct 16, 2019 - 11:34 AM.
Think about it, modern formula boats with self tackers are designed to race around windward leeward courses. They will smoke a Hobie 18 sailing at high angles towards a Windward buoy and sailing the low angles towards a Leeward buoy. By comparison they are not all that fast in between. As Sam mentioned, it can really be a tossup between a boat like a Hobie 18 and a formula 18 on a reach if the formula boat cannot carry a kite. Boats like a North American rig 6.0 be a superior weapon in that condition. I’ve even seen some hobie 16s in really stout wind travel at speeds on a reach that my F-18 would rarely see. The F-18 will reach that speed at a much deeper angle though.
How this relates to the OP is it doesn’t really say anything at all about either skippers skill or much about the boats. It’s quite an apples and oranges comparison. If neither skipper actively participates in racing, it’s likely they have little idea how much or little they might be sailing their boat to their full potential.
understood and makes sense - this is all good data
but - are you calling the H Fox a modern F boat?
bacho wrote: Think about it, modern formula boats with self tackers are designed to race around windward leeward courses. They will smoke a Hobie 18 sailing at high angles towards a Windward buoy and sailing the low angles towards a Leeward buoy. By comparison they are not all that fast in between. As Sam mentioned, it can really be a tossup between a boat like a Hobie 18 and a formula 18 on a reach if the formula boat cannot carry a kite. Boats like a North American rig 6.0 be a superior weapon in that condition. I’ve even seen some hobie 16s in really stout wind travel at speeds on a reach that my F-18 would rarely see. The F-18 will reach that speed at a much deeper angle though.
Modern when compared to a Hobie 18.
To Bacho's point. I have a Hobie 16 and a Nacra 6.0 NA. The Nacra is so much faster the two can't be sailed side by side. Up wind down wind they might as well be sailing on different lakes.
However, when conditions are perfect for high speed runs, my H16 has seen 19.7knts whereas my N6.0 has only seen 19.1 knts.
Also, I do a lot of distance cruising, The fastest 1 hour average I've seen on my Hobie has been about 12knts and the fastest hour average I've seen on the Nacra is over 15knts.
All these numbers produced from my 959nm and counting sailing summer.
Kevin
81' Hobie 18
Lake Michigan South Shore Line
Sorry but there is no comparison between modern Formula boats and the 70's designed Hobies. My F16 with main, jib and spinnaker on the water weighs 240 lbs.
It is not apples to apples if you say a Hobie can keep up if the Formula boat doesn't carry its kite. W/L have already been discussed. You can look to Statue race results if you want to see which boat comes out on top in distance situations.
Again, I do understand why the H16 continues to be popular on the racing scene but it is apples and oranges.
Agreed
however .... every boat has it's day
and as the OP stated... he was beating up on an F20 with an ancient 18
WELL DONE! :prost:
PS i have had my clocked cleaned repeatedly by a 70 year old fart on a 30 year old stock 5.0 g-cat
I sail a loaded down 5.5 mystere (basically a f18) he was outsailing me taking advantage of every trick in the book to beat me back to shore (5 miles)
his 50 years of catamaran sailing and building experience trumped my 20 years of cat sailing
his boat could sail in shallower waters, and his boat weight was a few 100 less than mine
as i said, every boat has it's optimal wind and weight range - add skills and the better sailor will probably prevail
Edited by MN3 on Oct 18, 2019 - 09:04 AM.
Makes a lot of sense about the angle of sail and what these boats were designed for, either way the day was fun as hell and I’m satisfied with the old Hobie 18’s performance. Also, wind speed was about 10-12, just enough to get the windward hull skimming the water.
Edited by car_guy on Oct 18, 2019 - 11:40 PM.
It sounds like he's talking about me. My G-Cat is over 30 yrs old and I'm 69. The sailing club to which I belong has a handful of F-18s which go out most late afternoons. I know their boats are faster, point higher and with spinnakers forget down wind. However on a beam reach I can keep up pretty good keeping in mind I paid 2k for my G-Cat and all I've done to it is add new sails. Simply put, every thing being equal, I think that the biggest common denominator for speed in modern beach cats is size. There is of course a difference but it is so small that skill level or one verses two on the boat will easily make a difference. When you're blasting along can you really tell the difference between 18 and 18.5 kts?
Hi Guys! I just now found this thread. Car_guy, was this in CT? Then it was likely me on my Hobie Fox, and I can offer some insight. Yes, you were definitely pulling away from us, sailing your boat fast.
Yes, 3 of us onboard, about 500 lbs. of crew. But that wasn’t the problem. The previous owner had hit plenty of rocks with both dagger boards, damaging the boards, but worse, the rear of both daggerboard trunks in the hulls. Leaking on both sides, so probably 15-20 gallons of water in each hull. So 500 lbs. of crew plus hundreds of lbs. of water onboard. I had the hulls repaired last Summer so it’s nice and dry inside when I pull it out of the water. Would love to sail with you again, either heads-up, or I crew on your boat, or vice versa. Was only able to sail 2x last Summer (2020), and not yet this year, but hoping to get out there soon.
