G cat 5.7 sails 1980-02
ko51
 ko51
(@ko51)
In need of sails is there any other cats out there with the same size sail as the 5.7 in need of both main and jib . Would look at good used sails
Thanks Graeme
Canada BC
Posted : August 29, 2011 12:08 pm
(@almax00)
sail specs for 5.0 and 5.7: /wp-content/uploads/images/80985.jpg
Posted : August 29, 2011 1:10 pm
havliii
(@havliii)
A Prindle 18 main sail is a dead match for the G-Cat 5.7 main. The jib is harder to match since the G-Cat jib goes past the bridle and tacks onto the forward crossbeam. You can use the Prindle 18 jib but you give up about 4 square feet of total sail area. (The Prindle jib will tack at the junction of the bridle wires)
I used the P-18 set-up on my 5.7 and it was faster than with the original G-Cat sails, due to the fact that the P-18 sails were built by Randy Smyth. Better cut, better cloth and better battens equals more power! I sold the boat with both sets of sails and the new owner also prefers the Smyth sails over the OE sails.
Posted : August 29, 2011 11:59 pm
a larger sail can be cut down to fit
i sail with a 5.7 that uses a tornado main and full sized jib. the jib blocks have been moved back a foot and are attached via the tramp lacing.
Posted : August 31, 2011 1:03 am
ko51
 ko51
(@ko51)
How much did you have to cut it down by ,would like a biger jib or sail
more HP
MN3 wrote: a larger sail can be cut down to fit
Posted : August 31, 2011 7:48 am
a g-cat 5.7 mast is 28' a Tornado mast is 31'.. so they had a good amount of cutting ot do. Often they convert a pin top to a flat top
First (and 3rd) boat is a g-cat
Posted : September 1, 2011 1:19 am
ko51
 ko51
(@ko51)
just found an other cat a Sol-cat 18 foot any thoughts or ways to find out how old she is . Only pay $250 for the cat going to redo her for next year. still looking for sails for the G cat 5.7
Posted : September 6, 2011 2:25 pm
ko51
 ko51
(@ko51)
Allso in need of sails for the Sol Cat-18 to both jib and main
Posted : September 6, 2011 3:53 pm
(@Edchris177)
Captain
ko51
 ko51
(@ko51)
Is the Sol-Cat 18 the same size sails as the G Cat 5.7? I thought it was just about the same size
Posted : September 9, 2011 2:40 am
(@Edchris177)
Captain
Not sure, I just saw in the post above you were looking for Sol Cat gear
Posted : September 9, 2011 5:39 pm
