Doh - Foiled again!
i am not upset at all - we have just witnessed and benefited from the most ground breaking advances in the sport since the invention of the sail
i am a multi huller - 100%
but foiling monos at this level are cool as dry ice
these are fast fast fast boats and although they will be slower than multis, it can still be a great show
the last AC was pretty boring to many cat sailors - and this slower speed may turn out to be much more exciting (and bring more people into the sport)
Here is another way to go across the bay:
Going really fast and taking care of business too! 😎
If you're going to get foiled, you may as well do it on a beachcat, no?
(I should try call my mom from the trapeze wire next time...)
Edited by martin_langhoff on Sep 15, 2017 - 05:18 PM.
Good question! Depends on whether we're foiling, speed and seagrass density. Note that the foils' vertical struts have negative rake, so anything caught there tends to slide upwards...
If we're foiling, going fast, and the seagrass patch is not too dense, we catch very little, cut some, and the rest slides off quick. If we're foiling slow and/or the patch is very dense, we slow down, stop foiling... swear some.
If we aren't foiling, we catch a ton of it, and requires manual removal, with lots of swearing because of the rake...
That is what i expected
we have sooo much grass in our bay and even gulf ... it has proven to be a foil fowler (we had hobie tri foilers try, and WindRider Rave - all fail
What do you mean cut some?
I think the foils, at speed, get to literally cut some of them. The leading edge of the foils isn't a knife, but can cut the skin of your shin if you walk into it, as a friend of mine can attest.
Maybe I'm imagining things -- keeping the boat under control while foiling takes all of my attention, so I'm not looking. In any case, light to moderate seagrass we get through ok when foiling, and clears out quick.
cool
i was lifting rudders and boards all day yesterday
was dreaming of a system that actually runs a razor up and down the board to quickly clear them....
martin_langhoff wrote: I think the foils, at speed, get to literally cut some of them. The leading edge of the foils isn't a knife, but can cut the skin of your shin if you walk into it, as a friend of mine can attest.
