Catamaran Speedometer
10 Users
André
(@catmodding)
Hi,
A topic on speedometers (can't find it) made me figure
out this simple setup. Used the padle as a boom-extender
and a Garmin gps.
Yesterday I did a test-run, here's the result.
http://www.youtube.com/watch?feature=player_detailpage&v=XALVwzZJs3Y
André
P 18-2
Posted : April 26, 2013 1:38 am
(@damonadmin)
Admin
Like it!
Posted : April 26, 2013 5:28 am
(@benedict)
Same here! That's cool.
Posted : April 26, 2013 1:59 pm
(@rehmbo)
Like it too. Is it reading kph or kts??
Posted : April 26, 2013 9:26 pm
André
(@catmodding)
rehmbo wrote: Like it too. Is it reading kph or kts??
Jeff, its reading Knts, nautical miles.
André
P 18-2
Posted : April 26, 2013 10:14 pm
Rob Hangen
(@rch701)
I have an old analog speedo that was given to me with my H-18. Imagine a 3/8" aluminum pole with a plastic prop on the end. i tried it once, but the cat goes so fast i could barely hold the darn thing in the water.
Rob
Posted : May 2, 2013 12:48 am
HAHA, ANALOG~!
I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
Every time they come up for air (i assume they will get dragged under often) they can yell the current speed reading to you (in-between their gasps for air)
rch701 wrote: I have an old analog speedo that was given to me with my H-18. Imagine a 3/8" aluminum pole with a plastic prop on the end. i tried it once, but the cat goes so fast i could barely hold the darn thing in the water.
Posted : May 2, 2013 2:28 am
(@klozhald)
Master Chief
MN3 wrote: I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
I recall seeing a harness for keeping the crew and analog speedo under the tramp, out of the sun. I think there was an optional Playmate cooler rack/snorkle to add to the crew's comfort.
It had a light so it could be read after sundown as well.
Posted : May 2, 2013 5:24 am
nhanson
(@nhanson)
Well done... I will be hijacking your setup idea. I will have to see if my LCD is readable 4 or 5 ft back tho.
Posted : May 2, 2013 11:42 am
bernd
(@vkm)
i did the same on my trimaran on the end of the bowsprit and a gopro3
http://www.youtube.com/watch?v=Wd8t5sRqP30&list=UUlQiUUws45hdszGx0LqvYgQ&index=2
bernd
Posted : May 2, 2013 11:43 pm
(@27fountain)
Maybe utilize a speedo like on a yamha wave runner. Has a 1" paddle wheel that spins that calculates speed and sends to a readable unit??
Posted : May 6, 2013 11:55 pm
(@27fountain)
And attach to be k of a hull. Maybe one for each hull?
Posted : May 6, 2013 11:56 pm
