Catamaran ID - Anyone care to take a stab at this one.
From this picture, the beams on the dart are tear dropped like the prindles.
The main travler is A cat'ish but don't know of an A that was a skeg boat.
Not a Nacra 5.7, bow is wrong and travler and the way the beam is seated in the hull.
Looks like a uni with an old style spin or hooter. I'm with Damon, what is that in front of the the main beam?
Any measurements, length, width, mast height?
Ron Beliech
Nacra F-18
Brandon, MS
Not a Dart 18, there is one down the lake form me, they have front beam mounts that wrap smoothly around the beam. Sea Spray have a mount like that, but I think they were only built as 15 footers. The Dart does not have vertical bows, Rons photo above shows the shear at the bows.
Ron...are those dagger trunks? It looks like skeg hulls, but there appear to be trunks on each hull.
Those fittings forward of the beam appear to be laid on top of the hull, then attached. Maybe a mod that was done to accommodate a forward net or tramp?
Edited by Edchris177 on May 07, 2012 - 06:10 PM.
Edchris177 wrote: /Ron...are those dagger trunks? It looks like skeg hulls, but there appear to be trunks on each hull.
I saw that too but they sure are short, back to front. I'm thinking older skeg boat from what you can see from the spin pole but the mast looks more modern, carbon fiber, wing mast.
Would like a pic of the mast post, and base.
To the OP any serial number on the stern?
Ron Beliech
Nacra F-18
Brandon, MS
This was taken at the mug race at the start in palatka, the gentleman did quite well and is a really experienced sailor. the boat is actually made of marine plywood, limited production run of 40 and he thought this was the last one. it was designed by Cal Fuller. that is all the hints i have without giving the answer. i think he said it was 20 feet long. he was in the mhsc.
Edited by klppurdy on May 08, 2012 - 06:50 AM.
I doubt that they are line antifouling devices. If you notice, the fixture wraps the entire deck and down each side of the hull, pretty significant attachment. The end appears to be slotted with attachment holes in the ends. With all that said, I still don't have a clue what they are for, unless they are for a spinnaker pole attachment point like you might use on a monohull. Thats my WAG (WILD ASS GUESS)
http://www.lakehopatcongnews.com/index.php?option=com_content&view=article&id=1089:qcatamaran-legendq-has-roots-on-lake-hopatcong&catid=13:local-news&Itemid=461
A-Cat. What did Headhunter and I win?
That's a great story, I enjoy reading about the early builders.
Ken, do you know what the deck fixture is for? After examining it as close as possible and seeing how substantial it appears, I think it could even be an attachment point for a kite. There have been a lot of experiments running kite sails on catamarans.
Do you know what it's for Ken?
klppurdy wrote: well done headhunter and mummp, no prize, only satisfaction.
The first picture its deceiving, I thought had it had skegs too for a couple minutes. Then realized the ass end was just elevated from the ground. There was a guy, Bob Kruger, in the Chesapeake in the early 70's making A-class cats the same way...4mm marine ply wrapped around bulkheads and tied with copper wire at the bottom, then glassed over. When Bob needed to make modifications to the hull shape, he'd break out the chain saw.
I'm Jon. I don't need a signature.
