Best knot for trapeze dog bone?
11 Users
car_guy
(@car_guy)
Simple trapeze setup, what is best knot for dog bone to ensure I don't end up in water watching my boat sail away?
Posted : August 28, 2015 11:46 am
(@Edchris177)
Captain
I have used the anchor knot. Easy to tie, easy to undo, but won't come undone. It is also compact, you can easily make the tail almost zero, & it yields almost full line strength.
http://www.apparent-wind.com/knots/anchor-hitch/
Posted : August 28, 2015 3:30 pm
car_guy
(@car_guy)
I like it, thanks Ed.
Posted : August 29, 2015 1:26 am
(@Dogboy)
For an added measure of security, throw an overhand knot in the tail end so if it slips, it can't come undone.
Steve M.
Posted : August 30, 2015 12:30 pm
Dennis Meulensteen
(@dennisMe)
I always use a bowline for this, have for as long as I can remember.
http://www.apparent-wind.com/knots/bowline/
Posted : August 30, 2015 10:48 pm
car_guy
(@car_guy)
dennisMe wrote: I always use a bowline for this, have for as long as I can remember.
That's what I was using but on my last outing in pretty rough weather my righting line tied to dolphin striker via a bowline became untied. I've always heard a bowline can come apart when not under tension but this was the first time I actually experienced it.
I switched to anchor hitch with overhand knot in tail and it seems ultra secure.
Posted : September 1, 2015 1:39 pm
(@yelkenli1)
I am not familiar with the anchor knot's performance, but would suspect both it and the bowline would benefit from having the bitter end seized.
Posted : September 1, 2015 2:30 pm
(@Edchris177)
Captain
Growing up in the Rockies, & doing technical climbs as a young man, this was THE PRIMARY reason a bowline was never used as a life line knot. A double bowline was acceptable.
Once you hang on the wire a few minutes, (using any "knot holding" line, like Sta Set etc)the anchor knot pulls tight. No matter how hard we beat the boats, they have never worked loose, either as actual anchor hitches on power boats, or dog bones.
Posted : September 1, 2015 6:29 pm
Dennis Meulensteen
(@dennisMe)
I'll look into using the anchor knot for my righting line. I've had that come loose too, also with a bowline. The traps have never though, but I always keep them really tight. I'll replace two knots and compare.
Looks like the anchor hitch with a stopper is a better option then.
Posted : September 3, 2015 10:29 am
(@Dogboy)
Overhand knot also works in the tail end of a bowline to help keep it from working loose when not under tension. We do this all the time when securing the ends of the downhaul line to the shrouds. A couple wraps of tape also go a long way for securing any knot you want to be permanent.
Steve M.
Posted : September 3, 2015 12:36 pm
(@klozhald)
Master Chief
edchris177 wrote: It is also compact, you can easily make the tail almost zero
The key to any knot holding is setting it under stress, and using rope that takes a set. Edchris' comment is applicable to a number of knots, including the bowline.
When you cut your line, use heat (flame) to mushroom the end. After you tie the knot, put a working load on it to set the knot. Get it tight. On an anchor knot or bowline, this means the mushroomed end is up against the knot. My dogbones have been tied this was for decades without failure. I was ocean sailing a few weeks ago and a bowline I tied on a retaining line (but did not set with force) came apart while I was sailing. My fault, not the knot's.
That said, firemen and climbers here tie a slightly different bowline. Imagine that the "rabbit" goes around the tree the other way, and the bitter end ends up on the outside of the knot instead of in the loop. They use a long tail, and tie several overhand knots with it around the loop. This is off track, and not intended to be a solution for you. Apologies. My $0.02.
Posted : September 3, 2015 2:14 pm
(@0rion85)
I've always tied a bowline with the tag outside the loop, made more sense to me.
Posted : November 1, 2015 10:18 am
bowlines can fail when there is loading and unloading (like a boat on anchor )
Posted : November 2, 2015 3:48 am
(@stumble)
I just splice mine in place.
Posted : November 2, 2015 7:20 am
stumble wrote: I just splice mine in place.
even though 8 and 12 strand is very easy to splice, most cat sailors i personally know don't know how to use a splice
I can use a fid (or wire) but prefer the Toss wand. it works very well
http://www.briontoss.com/catalog/kits.html
Posted : November 2, 2015 1:12 pm
(@Edchris177)
Captain
+1
Another option, what I do on the end of my tramp tension line,(slippery hi tech line), is to pull it in a favourable direction, the apply a zip tie.
Posted : November 2, 2015 2:51 pm
(@stumble)
MN3 wrote: [quote=stumble]I just splice mine in place.
In that case I would suggest encouraging people to learn. I figure it takes me less than 5 minutes to eye splice dyneema, and most of that is just looking for where I last left my splicing kit. Relying on knots in dyneema is just poor practice.
Posted : November 2, 2015 5:35 pm
(@rcnesneg)
The Bowline is inadequate.
Earlier today I left one of the four trapeze dog-bones from my F-20 cat at the bottom of the lake, after the bowline undid itself three seconds after I got on trap. Crew sailed away, capsized, turtled, and had to wait till I was deposited back aboard. In the process I also broke the 10 foot telescoping hot-stick.
I will be replacing all the small lines that tie to the dog-bones with something nicer than cheap west marine 1/4 inch line and will definitely be splicing the ends.
Posted : October 1, 2016 8:13 pm
tominpa
(@tominpa)
Wow, glad I read this! Thanks again Ed for another knot, and may try my hand at some splices. I've been using bowline knots as long as I can remember for many applications. I never dropped off, but this old dog can always use a new trick.
Posted : October 2, 2016 7:48 am
