Anybody do graphics?
Just about anyone can print (actually, they laser cut) vinyl for boat names or graphics on hulls. I sourced mine from a local sign shop. It was cheap.
Sails are a bit trickier. The material used is something called stickyback. I have found that only sail shops (or shops that make fabric advertising stuff like tents) work with this material. If you're only talking about lettering, it should be quite cheap. If you're talking about a picture, then it will need to be printed by a shop that has a large format printer, then affixed to each side of the sail. Its a labor intensive process. This only applies to the heavier sails made of dacron. For lighter sails (e.g. spinnakers), printers will use inks that are hand applied over a stencil.
Check out North Sails http://www.northsails.com/Default.aspx?alias=www.northsails.com/graphics . They did my sails (stickyback graphic on the main) and a spinnaker (inks over a stencil). Ask for a guy named Whitney. They were great to work with.
