5.5 low wings
8 Users
(@revintage)
Trying out new low wings on the old nacra 5.5 on Swedish lake Malaren in 8-16knt on this nice autumn day. The leeward wing lifts, using a pair of small blocks and a 3mm Dyneema rope, when you sit on the windward one, making it possible to set them so much lower than the commercial high, sofa like racks. The slim hulls aren´t really capable to bear three persons, still we logged 17knts.
http://racerdirekt.com/0927.mov
Brgds
Lars
Edited by revintage on Sep 28, 2017 - 07:50 AM.
Posted : September 27, 2017 11:40 pm
looks neat
how does it pivot ?
What makes "low" better than another wing?
are you out further from the boat?
Edited by MN3 on Sep 28, 2017 - 03:18 PM.
Posted : September 28, 2017 3:43 am
tominpa
(@tominpa)
Looks like it uses the trap wire to support raising and lowering on the front corner, and there may be a second eye midway along the wing? Can't see where that line terminates or cleats. How is this mounted to the crossbars? That is a lot of leverage.
Posted : September 28, 2017 4:01 am
(@dmgbear55)
This is very interesting. I would like to see more details of how the wing tubes are joined or mate to the beams.
These kinds of aluminum castings to join the tubes are very common for whitewater raft frames, so readily available at NRS and other providers.
An example:
https://www.nrs.com/product/91028.02/nrs-lopro-frame-fittings
Posted : September 28, 2017 7:30 am
nofearofflying
(@nofearofflying)
fantastic,i too would love to see diagrams/plans for construction installation-sailing mate Joe lost 1 bench in nacra 570 capsize, and I lost pair of factory benches with prindle 16 theft. Do you think i could modify so they affixed to Dart 18?(Have 2,lost 1 Dart to hurricane Irma) What benefit to low close to water bench/wing? Great video, Looks like summer over in Sweden[email][/email]
Posted : September 28, 2017 9:50 am
(@revintage)
Mating to the beams are made very simple using 60x40mm U-beams and 6mm bolts. Tubes are 50x2mm. The dark grey joints are made of sturdy PVC used for water piping while I found the aluminium ones in Germany http://www.brinck-rohrverbinder.de/shop/Rohrverbinder/-Oslash;-50-mm/T-Verbinder-5540::2713.html.
I am using both trapeze wires, one in each corner of the wings, with lifting and lowering only at the front. As the leeward wing lifts, there is slack in the leeward rear wire, ie it will not get in the way of the mainsail even on a broad reach.
Lowering the center-of-effort of the ballast is a no-brainer 😉 .
Pic below is from the first try. Clic the pic for details.
At the beach:
No summer in Sweden, just a few sunny days with 15-18 C air temp.
About Dart I guess you will have to place the "hinges" on top of the beams but inside of the hull fittings. Will actually place the next version on top of the inner beam straps. Will come back about that when tested.
Brgds
Lars
Edited by revintage on Sep 28, 2017 - 04:55 PM.
Posted : September 28, 2017 10:40 am
(@Dogboy)
It is an interesting idea, but it also seems like having the wings only held down by gravity could be a fairly major liability during a capsize. Not sure how much fun it would be to be sitting out on the wing as the boat goes over and then having the entire wing fold in and dump you off. I could also see there being potential (safety) issues with the wings being unsecured with the boat on its side or the wings slamming back down when the boat comes upright.
Steve M.
Posted : September 28, 2017 4:08 pm
Andres Chianale
(@Andinista)
Lowering the center-of-effort of the ballast is a no-brainer icon_wink .
The factor between tilted and horizontal wing is cos(angle), assuming it's the same length
When it's about man on the trapeze, length can't be extended, only angle can be adjusted, therefore trap systems are adjustable. But with the wings, you could make longer ones to compensate for cos(angle) and forget about it. So I would question if it's really worth the effort to make them adjustable.
Actually the math is not that simple, the above is valid only with the boat horizontal, as the boat heels, the tilted wings would be less and less effective compared to ones aligned to the beams. But on one side I think this effect is not so relevant and on the other, if the hull can't be kept low it means it's time to adjust something else
Posted : September 29, 2017 2:39 am
(@revintage)
Good thinking sm,
Actually got the foldable idea from M32 and they seem to accept full fold when capsizing 😉 .
If one wants to prevent a total fold when turning over, a stop could easily be adapted to prevent the wings to fold more than the leeward lift.
The wings are fairly light at 15kg/side(no prob as we are both fairly light) so another solution is to add a elastic line in parallell with the 3mm Dyneema "lift line" to keep the wings down/unfolded when not loaded by the crew.
Will rebuild this winter as I have a pair of 18SQ beams on their way from Holland. Will then be able to shorten the wings ca 30cm/side.
The reason for adding wings is that we are retired, without the acrobatic skills to trapeze any longer 🙂 .
Edited by revintage on Sep 29, 2017 - 08:49 AM.
Posted : September 29, 2017 2:47 am
interesting
Edited by MN3 on Sep 29, 2017 - 09:03 AM.
Posted : September 29, 2017 3:00 am
(@revintage)
Hi Andinista,
You are right about that, but to be picky it is not only about cos when you tilt the wing. If going for an extremely steep tilt like 45 degree, which is typical of the beachcats with fixed wings, compared to horizontal, you loose 1-0.707 times the wing width in righting arm. On a horizontal(or just above) wing you can also change your body CoE more easily by hiking with your back more to windward like with a trapeze, ie the the more tilted the more upright you sit with your back.
My idea was to mimic the position you get when using trapeze. But also get some righting arm. In the position I sit on the first image I get about 20cm more leverage compared to trapeze.
Having tried angles from to horizontal I have found just above 10 degrees works best. When going horizontal it´s a pain to rise up from your comfy position even though I have left the trapeze handles on the the wires 😉 .
In purely mathematical terms the differencies might not be big, but you get the feeling of a more stable and balanced ride the lower you get.
Edited by revintage on Sep 29, 2017 - 11:55 AM.
Posted : September 29, 2017 5:46 am
Andres Chianale
(@Andinista)
OK. So it's more about functional factors, and you have been experimenting, now it makes more sense to me. Interesting
Posted : September 29, 2017 9:14 am
Andres Chianale
(@Andinista)
Your beachwheels also called my attention. I had thought of something like that but separate sets for each hull, would that work too? Not needing wheels today but who knows in the future..
Posted : September 29, 2017 9:26 am
(@revintage)
It would absolutely work. About the wheels it is also my intention to remove the tube between, it isn´t even bolted. Probably one should add an elastic strap to keep them in place on each hull. Will go for that when I add the wider beams.
Another idea stolen from M32, that uses 4 sets 🙂 .
Posted : September 29, 2017 10:22 am
Andres Chianale
(@Andinista)
Cool. Yes, I thought of a strap too. It wouldn't work aft of the front beam, but it's about enough on that boat (same as mine)
Posted : September 29, 2017 10:33 am
(@revintage)
Hmm, didn´t think about that. I usually have to place the wheels just behind the front beam. Might be able to sneak the strap in the corner just aft of the beam, before the trampoline.
Posted : September 29, 2017 10:53 am
Andres Chianale
(@Andinista)
maybe one line only. It would also be hard to grab the other end
Posted : September 29, 2017 11:24 am
(@dmgbear55)
Are the cradles laminated wood, or a composite construction? Your wheels look like they are similar to wheelbarrow wheels, did you snitch some hardware from your wife's garden shed?
Posted : September 29, 2017 1:16 pm
(@revintage)
Haha, no it´s actually the cheapest 8" wheels I could find, had to drill them for 1" axle though.
Still I am not satisfied with the wheels, need something with a flat profile. Wonder if 6" width and 11" diameter is enough? Guess 16" diameter would be better but they are awfully expensive
Cradles seems to be GRP clad with carpet, got them together with the boat and seems to be made for beachcat trolleys.
Will test without centeraxle next week, might take a snapshot.
Posted : September 30, 2017 1:10 am
Andres Chianale
(@Andinista)
An idea: Put two lines on each set, with some sort of quick attachment at each end, one end attached at the shroud and the other at the front beam or maybe at the forestay bridle. Both starting from the center of the cradle to avoid rotating it. A long line towards the bridle may seem too much but it would probably be handy to retrieve the wheel from the bow on the water. All this just to avoid that the cradle slides along hull, i'm assuming that would be enough to keep them there.
Sorry for the off topic...
Edited by Andinista on Sep 30, 2017 - 10:22 AM.
Posted : September 30, 2017 4:21 am
(@revintage)
Good idea if I have understood it right. No technical discussions are off topic in my world 🙂 . Just found out M32 uses Starco Flex Lite 16" wheels.
Edited by revintage on Sep 30, 2017 - 11:13 AM.
Posted : September 30, 2017 5:07 am
(@dmgbear55)
If your tires have inner tubes You should see just how low you can take the air pressure down before the tires start dismounting themselves. The contact patch of the tires will increase dramatically as the PSI goes down. If the tires are tubeless then this will not work very well or at all.
For sure I will be messing around in my shop this winter building a set of wheels like yours. The beaches we have here are generally pretty hard sand, or fairly tight gravel and we can run our trailers right to the water, but not always.
Posted : September 30, 2017 6:27 am
(@revintage)
dg, will lower the pressure at once, as they are now they don´t even work in course sand.
Nice price! Only 3500USD/set. Still using Starco wheels at ca 30USD/pc......
http://shop.m32world.com/product/launching-trolley/
Edited by revintage on Sep 30, 2017 - 01:01 PM.
Posted : September 30, 2017 6:57 am
(@revintage)
New wings 2018. Also made them telescopic for widening when going single hand. Weight close to 10kg/pair. As previous version leeward lifts when sitting on windward wing.
Posted : June 16, 2018 2:01 pm
(@ctcataman)
Master Chief
Do the wings go up and down during a tack? If so, very cool.
Posted : June 17, 2018 1:55 am
(@revintage)
Hi John,
Tried this last year and it works like a charm. When you load one wing, the opposite rises. Can allthough be easily modified to lift both wings, when neither is loaded, only two small bungee cords needed.
A very simple system with a 2-3mm dyneema(red in the image) that turns around a small block, above the diamond tangs and the hounds, in front of the mast. The dyneema could be turned lower but this increases force needed and also gets in the way of the spinnaker.
Edited by revintage on Jun 17, 2018 - 02:25 PM.
Posted : June 17, 2018 8:22 am
